PCM info for NorthStar
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Northstar Engines and System Technical Discussion Discussion, PCM info for NorthStar in Cadillac Engine Discussion; I am trying to do some digging on the NorthStar PCM, wondering if you N* owners can help. 1. Who ...
    N0DIH's Avatar
    N0DIH is offline Cadillac Owners Master
    Automobile(s): 94 Fleetwood Brougham
    Aug 2004
    Rockford, IL
    49
    7,531
    1. Who is the PCM supplier? I know it isn't Motorola, I suspect Delphi, as they are main GM supplier.
    2. What bus protocols for the 96-99 and the 2000-up? CAN, Class II (SAE J1850), ?
    3. Does anyone have any pictures of the inside with some IC's that can be identified?
    Thanks! I won't ask if I had a NorthStar car handy, but I don't.... Yet....
    Thanks
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Re: PCM info for NorthStar
    hmmm...what are you planning to do??
    N0DIH's Avatar
    Aug 2004
    Rockford, IL
    49
    7,531
    It's cracking time....
    I am determined to figure out at least WHY no one has been able to do it. And my goal is to succeed.
    We are working with standards, so I am puzzled why, is it just lack of effort or like Dodge did on the Hemi, encoded the output where it was harder to crack. But that defies the EPA ODBII standards.
    caddydaddy's Avatar
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Cool! Glad somebodys determined to crack the codes!
    N0DIH's Avatar
    Aug 2004
    Rockford, IL
    49
    7,531
    I talked to one guy who has cracked some LS1 stuff and said a new PCM takes around 3 months to crack. Maybe if we can get more heads together on the same goal, we can do it sooner.
    As we say at work, keep throwing bodies at it till it gets done....
    parts68 is offline Cadillac Owners Fanatic
    Automobile(s): 02 Escalade,96 Aurora,with Shelby engine
    Jan 2006
    345
    check with the guys at auto tap and see what they have
    Website claims to have a programmer for all GM OBD2 v-8s.
    Also some time back I inquired at SuperChips,whose right up the road from me,and they said they could custom program my 96 Aurora.
    I like the HP tuners that you can DIY.
    N0DIH's Avatar
    Aug 2004
    Rockford, IL
    49
    7,531
    Will do, odd, by the response on this thread, I can see why no one has messed with breaking the code, seems like there is very little interest. Or am I just reading this wrong?
    ShadowLvr400's Avatar
    ShadowLvr400 is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Fleetwood
    Oct 2003
    Central Florida
    34
    2,536
    I lost some of the interest when I switched from a Northstar to an LT1. The thing I think it might be, is not too many people know how to crack car computers. So they can offer little advice, and are tring not to clutter up a thread. As for getting a computer, I'd hit a junkyard, and save some $$.
    94CaddyConcours's Avatar
    94CaddyConcours is offline Cadillac Owners Fanatic
    Automobile(s): 1994 CADILLAC DEVILLE CONCOURS, 350ZR
    Jul 2004
    LONG BEACH KALIFORNIA, HOUSTON
    444
    Well is it delphi? And whats the part number?
    I dont think it delphi since I could only find part that are for delphi:
    Alternator Camshaft Sensor SS10003
    Compressor
    Condenser
    Coolant Temperature Sensor
    Crankshaft Sensor
    DIS Coil
    DIS Module
    EGR Valve
    Electric Fuel Pump FE0073 Stamped EPT Or EPW On Sender
    Evaporator EP20003
    Fuel Injector FJ10054
    Fuel Strainer FS0030
    Heater Core HC0172
    IDLE AIR CONTROL VALVE CV10049
    Knock Sensor AS10007
    MAP Sensor PS10058
    Modular Fuel Pump FG0010 Stamped EPV On Sender
    Oxygen Sensor ES10049 2 Required
    Radiator RA1208 -
    W/EOC
    W/TOC
    Throttle Position Sensor SS10429
    Wire Set
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    Quote Originally Posted by N0DIH
    I'd try and find this stuff out but mine's a 95, don't have a 96+ handy either.
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,215
    You are't going to get much help from AutoTap. Their latest adapter and Beta software will let me access nine generic parameters in my '04 CTS. They are way behind the curve with CAN enabled stuff.
    Feb 2004
    FL
    2,250
    Because it's work. Unpaid charity work at that.
    On top of that, you have to have a solid foundation in assembly, and electronics (to decode the ALDL stream, translate that into memory locations, and go backwards)... Having a schematic obviously would be a big help (there are none).
    To be frank, it's a big PITA with little to gain. Say you did crack it, what do you gain? Maybe a few extra horses when you can modify the spark tables a bit? Change the rev limiter? MPH cutoff? What's the ultimate goal?
    N0DIH's Avatar
    Aug 2004
    Rockford, IL
    49
    7,531
    After seeing the amount of parameters in the LS1 code, what you can do is amazing. I guess for me, I like to mess around. And cars like Mark's, it might be a Godsend too. You can likely make the PCM use a 2 bar MAP, where now it is only a 1 bar. So the PCM can manage all the boost calculations (timing/fuel) etc.
  16. #14
    Feb 2004
    FL
    2,250
    Like I mentioned previously in another thread, I am close to releasing a plug and play tuneable GM computer for the northstar. Boost will be a possibility. Custom tuning for cams, etc will be done with ease. It won't have all the features the stock OBDII computer will have, as it is OBDI, and it certainly won't talk to any of the other computers, but it will be a major step forward in tuneable, affordable northstar computers.
    That being said, I doubt anyone here would be interested in such a thing, it's mainly aimed at people with northstars in other cars (dune buggies, fieros, hotrods, etc).. i.e. people who don't care about all those other computer systems. But plug and play for about $500, with wiring harness is tough to beat. On top of that it's a GM computer with more features than anything Holley, etc can give.
    With respect to the OBDII northstar computer hacking, turning it into a computer capable of boost would be quite a feat. You would have to reprogram actual code segments. Hacking the computer is one thing, a very labor intensive (brain melting) thing, but actually rewriting code would be...well... painful. I'm not trying to stop anyone from attempting by any means, but I just see people asking "why isn't it hacked yet?" as if it's some walk in the park... It's not.
    Code:
      F4A7      LF4A7:ldaa  #0x40
       jsr      LF0C9
       ldx      #0xF8E2
       brset      *L002A,#0x40,LF4BC
       brclr      *L0004,#0x01,LF4BC
       ldx      #0xF8F3
       bra      LF4C2
       LF4BC:adda  #0x0A
       bcc      LF4C2                   ;BRANCH IF NO OVERFLOW, ELSE
       ldaa      #0xFF                   ;LOAD 255
       LF4C2:jsr   LF74A                   ;LOOKUP
       staa      *L00E8
       brset      *L002A,#0x40,LF4D3
       cmpa      #0x78
       bhi      LF4D8
       cmpa      #0x6A
       bhi      LF4DB
       LF4D3:bclr      *L0004,#0x01
    ^^ That's a sample of what I'm working with right now. If you can't read that in "english" terms, you have a lot of catching up to do. I have a very limited assembly knowledge. It's barely enough to get what I'm trying to do done. Hacking an ECM is beyond my reach...
  17. #15
    Zorb750 is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Eldorado, 2003 Audi RS6
    Apr 2005
    Oakland County, MI
    33
    1,320
    I say go for it. Let me know if there is anyting I can do to help, short of testing totally experimental software on my car.
  18. Remove Advertisements
