Engine ID
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, Engine ID in Cadillac Engine Discussion; I'm going to buy a motor from ebay. The guy said it is a crate motor and never been in ...
    denscor is offline Cadillac Owners Fanatic
    Nov 2005
    Point Pleasant,West Virginia
    51
    174
    Engine ID
    I'm going to buy a motor from ebay. The guy said it is a crate motor and never been in a car, how do you ID the motor? ENGINE PRODUCTION NUMBER: 6TU284981 There also is a number 9 on it. Thanks
    cadman59's Avatar
    cadman59 is offline Cadillac Owners Member
    Jan 2006
    Enid OK.
    67
    6
    Re: Engine ID
    I would ask a few questions first, the number you provided sounds more like a VIN number stamped on the engine than a producton number I have 2 Northstar engines out in the garage one is from a 2001, one from a 1996 both have a 6 where your number showed a 6. The final 8 numbers are the year and build sequence.
    I have access to GM's web site to check out VIN'S so I typed in that number and it shows that vin was built as a 1996 DeVille with the low horsepower "Y" engine (275-285? I can't remember which).
    It was sold 5/15/96 in Smyrna, GA It was last in a dealership for the fuel rail champaign on 12/19/05 at 73,023 miles.
    So check closely before buying, there is nothing wrong with a good used engine, but I know I would not want to spend $2-3K thinking I was getting a new engine and receive a used engine worth $1000 or less.
    Lance
    Nov 2005
    51
    174
    Re: Engine ID
    Thanks a billion! I'm not going to buy it now!
