1994 eldorado fuel pump
Results 1 to 5 of 5
Northstar Engines and System Technical Discussion Discussion, 1994 eldorado fuel pump in Cadillac Engine Discussion; I have a 94 eldorado with 170k miles and I probably need to change the fuel filter. Can you tell ...
    missosuricloserman is offline Cadillac Owners Member
    Jan 2006
    I have a 94 eldorado with 170k miles and I probably need to change the fuel filter. Can you tell me where it is and if it is very difficult to change. I also have a problem with it stalling sometimes when I'm stopped at a traffic signal with my foot on the brake and the car in gear. Anyone else have this problem?
    69
    82,269
    Re: 1994 eldorado fuel pump
    Have you ever cleaned the TB?
    Jimbad is offline Cadillac Owners Member
    Automobile(s): 1993 ETC, 2000 DHS
    Jan 2005
    Derwood, MD
    78
    59
    If the '94 is like the '93 then the big fuel filter is under the driver's side of the car. Just trace the fuel line and you will find it.
    Stalling sometimes caused by faulty EGR or even the idle-speed solenoid.
    Jan 2006
    What is the tb and how do you clean it?
    69
    82,269
    TB = Throttle Body.
    Remove the intake duct and MAF sensor. Block the throttle plate open. Spray the throttle bore and plate with carb cleaner. Scrub with a toothbrush and rag til clean. Don't forget the backside and perimiter of the throttle plate.
  8. Remove Advertisements
