4 Bad Headgaskets
Page 1 of 2 12 LastLast
Results 1 to 15 of 26
Like Tree5Likes
Northstar Engines and System Technical Discussion Discussion, 4 Bad Headgaskets in Cadillac Engine Discussion; So I recently acquired not only 1 but 2 vehicles with bad headgaskets. A 2005 Bonneville GXP and a 2005 ...
    Northstar125 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Escalade 6.0 AWD, 2004 SLS, 2005 Bonnie GXP
    May 2010
    Racine, Wisconsin
    24
    232
    4 Bad Headgaskets
    So I recently acquired not only 1 but 2 vehicles with bad headgaskets. A 2005 Bonneville GXP and a 2005 Cadillac Deville. Having never done one before I hope I'm not getting in over my head but I have read the extensive threads from different members detailing their headgasket replacement. The Bonneville has no oil leaks while the Deville does so I'm hoping not to have to tear into the bottom end of either one but we'll see when we get to that point.
    The Bonneville runs very rough and erratic with P0300 random multiple cylinder misfire. Whereas the Deville only has a misfire number 2 and seems to run fine when you "get on it." And the owner said the overheating was very intermittent and only occurred 3 times within 500 miles of driving.
    Anyways I'm looking for a list of things that I will need before I begin my quadruple bypass between these 2 cars. I'm assuming the engines are the same? So one service manual should be sufficient to do both.
    Here's a list of the things I have already purchased or will be purchasing as I get ready to do the job. Let me know if there is anything I am missing or anything I have listed that I WILL NOT need.
    I really don't want to go overboard here as both of these are budget builds BUT something as cheap as $8 radiator hoses WILL most definitely get replaced.
    Purchased:
    Kent Moore J42841 Rear oil seal remover
    Metal fuel line disconnect tool
    Front motor mount (not sure if it will be needed or not)
    KM J45930-A Rear oil seal press (Looking on ebay is $165-$200 fair or can I find one cheaper somewhere?)
    Studs
    Head gaskets
    Intake gasket
    Valve Cover gaskets
    Oil pan gasket
    Waterpump
    Thermostat & Seal
    Spark Plugs
    Oil
    Coolant
    TCC Solenoid?
    Transmission Side Cover Seal
    Transmission Fluid
    Radiator Hoses
    Exhaust Manifold Gasket
    Front Seal and timing cover gasket
    Rear main seal
    I usually buy ALL Felpro gaskets? Is that fine or are the OEM GM recommended in any instances?
    Also what is the best way of checking the block and head flatness? Is it absolutely necessary to take the heads in and have them gone through? Or is there a way I can check them myself?
    69
    82,376
    Re: 4 Bad Headgaskets
    Just lay a straight edge on the head and see if you see light under it, but I doubt you will. The heads never need any work.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,120
    Block deck checks, machinist's straightedge - laid diagonally from corner to corner - both ways - X. Front to rear, centerline of the cylinder bores. Essentially the same for the heads.
    ......... and you do not mill the block if the deck flatness exceeds .004" - you replace it. The heads will take a .008" mill from stock - total.
    The 2005 Northstar (from 2000 - - on) has roller cam followers with stationary lash adjusters. (Picture courtesy of JimD)
    04GrandAmGT's Avatar
    04GrandAmGT is offline Cadillac Owners Fanatic
    Automobile(s): 2001 DTS, 04 Grand Am GT,07 Cobalt(Dont Judge,My fuel Saver)
    Oct 2012
    Manitoba, Canada
    375
    Quote Originally Posted by Northstar125 View Post
    Felpro works just fine, just NEVER use there rear main seal. i hope the rear main you purchased was a GM Factory replacement.
    Need parts for your Northstar Engine? www.northstarperformance.com
    Evrett, Sales Executive of the SureGrip™ Cylinder Head Stud Kit
    Fifty9cadillac is offline Cadillac Owners Member
    Automobile(s): 1959
    Mar 2014
    36
    Make sure everything is factory replacement. I get all of my oem stuff from GM parts. But check the site and vendors for other places too. I can't say i've use the SureGrip stud kit. . . yet. Good Luck.
    JoeTahoe is offline Cadillac Owners Enthusiast
    Automobile(s): 2001 GMC SLT, Malibu LTZ, 99 STS studded with NP
    Jul 2010
    Central, NY
    49
    499
    Quote Originally Posted by 04GrandAmGT View Post
    I agree with this felpro top end kit and a felpro timing cover gasket. Only use the gm rear main seal. Rock auto has good prices on felpro
    04GrandAmGT likes this.
    May 2010
    Racine, Wisconsin
    24
    232
    Ok. Thanks for the advice.
    I've got another question for you guys. Had to move the GXP the other day and it started making some weird noise (didn't sound like a spun bearing but was metallic noise). Turned motor off, would not restart. So I'm assuming its hydrolocked. At this point I'm wondering if a junkyard engine wouldn't be a better course of action after all that?
    Feb 2006
    57,120
    Hard to say, but metallic clanging and banging followed by a no-crank condition is usually notice of expensive noises. If the engine is hydrolocked you could not turn it over with a giant crowbar.
    markmnj's Avatar
    markmnj is offline Cadillac Owners Fanatic
    Automobile(s): 1973 Cadillac Hearse, 2002 Cadillac DHS
    Oct 2013
    Hampton Township, NJ
    269
    An engine from a wrecking yard could be a viable solution. If it were mine I would still re-do the head gaskets and threads before installing a used Northstar since a good chunk of the work is in the engine removal/install itself. Nothing like a known set of values under the hood.
    rodnok01's Avatar
    Feb 2012
    NC
    6,719
    I agree since it would be out almost silly not to do it then, if any oil leaks perfect time to fix those too.
    May 2010
    Racine, Wisconsin
    24
    232
    But if I separate the midcase then at minimum I would have to replace the metal mid-case seal and crank bearings, correct? I want to fix it right but don't want to do things that are unnecessary and spend extra money. I guess going this route I could see if the bottom end was in good shape before putting it all back together.
    rodnok01's Avatar
    Feb 2012
    NC
    6,719
    Crank bearings and bolts can be reused. The rod bolts have to be replaced if removed.
    May 2010
    Racine, Wisconsin
    24
    232
    So its just the mid-case seal then? For some reason I remember reading about the bearing getting crushed/pressured or something when tightening the bolts? Was that regarding the rod bearings?
    When pulling the mid-case apart if the mains look good there is no sense in pulling rod caps, correct?
  16. #14
    69
    82,376
    Correct. That is why (to the best of my knowledge) they are not supposed to be reused.
    Actually, there is not much sense in opening the halfcase unless you are resealing it. The lower end is damned near bullet proof and the bearings seem to outlast the car.
  17. #15
    rodnok01's Avatar
    Feb 2012
    NC
    6,719
    The only reason I pulled my half case was major oil leak that became obvious with engine out.
    Main bearings were virtually perfect after 100k.
  18. Remove Advertisements
