1998 surging when accelerating
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, 1998 surging when accelerating in Cadillac Engine Discussion; My 98 SLS surges during part and wide open throttle. Idle and light highway cruise are smooth as silk. Other ...
    gman89 is offline Cadillac Owners Fanatic
    Jan 2004
    213
    My 98 SLS surges during part and wide open throttle. Idle and light highway cruise are smooth as silk. Other than the surge, power seems ok and gas mileage is good.
    The plugs are new.
    Any ideas?
    Tahnks
    68
    81,926
    Re: 1998 surging when accelerating
    Check your fuel pressure under those conditions.
    mcowden is offline Cadillac Owners Connoisseur
    Jun 2003
    1,164
    Quote Originally Posted by Ranger
    I'm with Ranger... It sounds like fuel pressure might be low under high demand conditions such as acceleration. Once you steady off on the pedal and fuel use is much lower, it's fine. It could point to a clogged fuel filter, a crud-covered screen on the fuel pump, a failing fuel pump, a bad fuel pressure regulator, a vacuum leak, and other things. But, as Ranger said, you should start by checking the fuel pressure while starting and while accelerating.
    Mike
