1994 Eldorado sometimes misfiring. Water in the Fuel?
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 25
Northstar Engines and System Technical Discussion Discussion, 1994 Eldorado sometimes misfiring. Water in the Fuel? in Cadillac Engine Discussion; Hi people. I'm new here and this is my 1st caddy. I'm happy that there is such a forum & ...
    rjpier61 is offline Cadillac Owners Member
    Oct 2005
    New Jersey
    55
    12
    Hi people. I'm new here and this is my 1st caddy. I'm happy that there is such a forum & website. I have had it a week & it's nice but I knew there were some issues. One thing I'm looking for advice for is that the engine runs strong mostly, it has just over 81,000 miles, but once in a while it starts misfiring, back firing and spuddering and I have no power until it clears. During this time the engine coolant temp rises quickly. up and unyil it will overheat. I thought it might be water in the fuel tank but I have been treating it with dry gas. I put on about 150 miles but this symptom of misfiring has happened quite abit. Then I thought it might be a head gasket but there is no coolent in the oil, no sweet smell at the exhaust but the coolent will blow out of the overflow relief line at the coolent cap only when the engine is sputtering (over heating or not) . Head gasket? Thanks for any advice.
    mcowden is offline Cadillac Owners Connoisseur
    Jun 2003
    1,164
    Re: 1994 Eldorado sometimes misfiring. Water in the Fuel?
    Quote Originally Posted by rjpier61
    You should get a cylinder pressurization test done. They (or you) make an air hose fitting from a hollowed out spark plug, turn over the engine to close the valves for the first cylinder you will test, then hook the cylinder up to 120 PSI shop air. If it holds 120 PSI, that cylinder is good, move on to the next. It will take some time, but it's a definitive test. A shop can also test for hydrocarbons in the coolant, which is a pretty good indicator but not always 100% accurate. The symptoms you're describing do sound a lot like a head gasket leak. On the Northstar, you won't see coolant in the oil if the head gasket is blown. If it's just blowing compressed air and exhaust into the cooling system, it will become overpressurized and come out the pressure cap, like you're describing.
    Use the Search feature above and look for head gasket. You can also look in the Tech Tips forum (use the Quick Jump drop down box below). There is lots of information about this problem available.
    Mike
    Oct 2005
    New Jersey
    55
    12
    Michael,
    Thank you very much for the quick responce.
    Ron
    68
    81,926
    When the cylinders are pressurized also look for bubbles in the surge tank (not what you want to see).
    Oct 2005
    New Jersey
    55
    12
    Ranger,
    Thank you too. I suspect it's probibly a head gasket. Hope it is at least on the front head. I'm going to purchase the factory service manuals because I want to do these repairs myself. Ha..... Actually I need to do it myself due to funds.... But your help in diagnosing may help limit unnecessary dissassembly.
    Thanks again.
    Ron
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    If it is the headgasket, even if it is the front head, it's a better plan to drop the cradle and do all 20 holes. Whatever caused the front one to go is working on the back one as well.
    Oct 2005
    New Jersey
    55
    12
    davesdeville,
    When you're right, you're right. Might as well do it right the 1st time and get it over with.
    Thanks,
    Ron
    Oct 2005
    New Jersey
    55
    12
    Ok......... Here is what I feared. I got the title today in the mail. It basically sat on a used car lot since March of 05. When I got it it had about 50 miles more than the last time the title was changed in March. When I picked it up it had just over a 1/4 tank of gas. So it sat for more than 6 months with between 1/2 & 1/4 tank of gas. Can the once in a while misfiring & sputtering be caused by water in the fuel or can the coolent cause this situation on and off. I pretty much figured it has a blown head gasket because the pressure in the coolent system blows before it reaches overheating temps.
    68
    81,926
    I don't think sitting for that amount of time would cause much problems. If you are in an area that has 10% ethanol, that would dry out any moisture in the tank. If not, add a pint or so of iso-somethingorother alcohol or an over the counter gas dryer to the tank to be sure. That would eliminate that that possible cause.
    Oops, rereading your first post, I see you've already covered that base. BTW, Northstars rarely get coolant in the oil through a blown head gasket like a conventional engine, so don't look for that symptom.
    Oct 2005
    New Jersey
    55
    12
    Ranger, ok thanks. What about possible coolent being sucked into the cylinder. Would it still fire correctly? It does fire fine mostly with plenty of power but just that every once in a while it's like I just sucked in water into the intake. It takes a while to clear the engine then it runs fine for a wile then starts again. Guess taking it one step at a time. But man!!!! I don't have a service manual yet but have been poking around online trying to fine a procedure on head gasket replacement with little luck. But what I see from some pictures, this is a design I'm not used to. I have done engine work years ago on 340 ci Mopar, 350 GM, 351 Ford but this overhead cam stuff. From the look of some cutaways it looks like I have to pull the front engine cover to expose the chains & gears. Looks like a mess and hard access. No wonder people do engine swaps.
    Ron
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    The head gasket job isn't that bad. If you've done work on other v8's you should be able to handle it.
    There's a thread in tech tips that gives a lot of info. Read it. If you ever timed a v8 cam you can handle timing 4 at once.
    It is hard to access "in the car". Drop the cradle and it's much easier. This is the curse of FWD. Not just Caddy but all FWD's are harder to work on. Make it a v8 and it gets REAL hard. It's just a matter of available space.
    Your question about intermittent leaking. Yes, that's what sends most people to left field. You do something and it seems to fix it , then it overheats again, do something else and it works awile. Eventually they get real bad.
    I try to get people to test for headgaskets right away, not because I think they all blow, but to save them from shotgunning an overheating problem that's really gaskets. Sometimes it is a radiator or purge line...sometimes gaskets. It's just doing good diagnostics and not spending a bunch of money unnecessarily.
    68
    81,926
    I think the answer to your question is maybe. A small leak would probably not affect the way it runs but a bad breach probably would as coolant is not flamable. Everything in your original post leads me to think it is not a head gasket, except for the overheating. I think you need to do the cylinder pressure test to confirm or rule out a head gasket for sure.
    Oct 2005
    New Jersey
    55
    12
    Zonie77, Thanks for the words of encouragement. The car runs at normal temps except when it starts misfiring and sputtering. After the episode it drops back to normal.
    Ranger, thanks again. I am going to go that route and pressure each cylinder. Should I go the 120 psi to eash cylinder route or 15 psi at the coolent cap method? I pretty much know what to do & what to look for on both methods but the 15psi seams easier but less reliable. I kinda think the individual 120 PSI on each cylinder would better narrow it down...
    I'm going to do this this weekend.
    Thanks guys!
    Ron
  16. #14
    Oct 2005
    New Jersey
    55
    12
    Thanks guys!
    Ron
  17. #15
    Eldyfig's Avatar
    Eldyfig is offline Cadillac Owners Connoisseur
    Automobile(s): 13 Challenger RT, 11 CTS Coupe Premium, 94 Eldorado (RIP)
    Jan 2003
    Folkston, GA
    1,306
    I see everyone is on the subject of headgasket, this is a big paranoia with North*s. Like Ranger said, I doubt your misfiring is a headgasket problem. First thing to check in any misfiring case is your plugs, then wires and coil packs. I didn't see any mention of this from your post. Have you checked them?
  18. Remove Advertisements
