Results 1 to 8 of 8
Thread: 1999 Deville Headgasket - head job or total overhaul ?
    Northstar125 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Escalade 6.0 AWD, 2004 SLS, 2005 Bonnie GXP
    May 2010
    Racine, Wisconsin
    24
    232
    So I'm looking at purchasing a 1999 Deville with a bad headgasket and I'm trying to total up the parts cost of what all I'll need.
    Obviously all the top end gaskets and a set of studs from Northstarperformance. But what about the lower end? I've head some horror stories when pulling the midcase apart then new bearings, crank, etc are needed.
    I'm very skilled but have never actually rebuilt an engine or went this far in depth (especially on a N*) but I think its worth a shot.
    Pretty much just looking for opinions on the lower end. Pull it apart or leave it? I'd prefer not to have oil leaks but I'm not going to spend another $1,000 in parts if that is what it needs.
    arctic_man's Avatar
    arctic_man is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Deville
    Jun 2008
    The Sticks, MN
    27
    269
    Re: 1999 Deville Headgasket
    Quote Originally Posted by Northstar125 View Post
    How much work do you want to put into it? Search this site, there is a thread by Bill Buttermore. He did everything to the engine. Completely refreshed it. He has many pictures, and cost breakdown. In addition to cost, it will take much longer if you choose to reseal the half case.
    When I did mine on my 99, I had studs, valve cover gaskets, water crossover gaskets, an oil level sensor that I broke, head gaskets, and I think that was it.... But my half case is not leaking. Total cost came somewhere around 600.
    In addition to the parts, you need the tools to do it. A good 1/2 socket set, and a breaker bar. Maybe some swivel sockets, extensions, and so on. Many users here have dropped the cradle from the bottom. You can do it with a large enough jack, but a cherry picker or hoist is most often used. You will need one of those. If you wish to do the half case, you will also need an engine stand. One large enough to support a V8.
    But do some research on this site. You will find a lot of guides on how people did it. You just need some tools, the right attitude, and know when to walk away and call it a day.... Oh and beer... lots of it.
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,689
    I'm very skilled
    you might be biting off a LOT more than you can chew -
    many professional mechanics will not touch a Northstar motor -
    too complicated - and the job takes too long -
  5. #4
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,993
    If you have halfcase leaks, then definitely open up the lower half and replace things.
    Basically you'll need new main bolts (or you can go with main studs from Northstar Performance). Rod bolts and bearings if you're going to pull the pistons. Why not replace the bearings when you're in that far deep? You can reuse the crankshaft though, that one's bulletproof. Oil manifold, rear main seal, etc. The rear main seal would require a special tool but there's always a workaround.
    I did an overhaul not too long ago on a 99, it cost me about $1600 total (and that's including a rebuilt alternator + a/c compressor + dryer. Actual parts cost is around $1200)
    If you do tackle on this project, I believe there are a lot of people here who can help you with every step. It's a good experience for sure. I did it. That means you can.
  6. #5
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,842
    Good sockets, wrenches, and torque wrenches. Various solvents and cleaners. DO NOT - EVER - get anywhere near an engine with a ScotchBrite pad. Patience. Time. A mechanical eye. You will NEED a real GM/Helm service manual for some procedures and torque specifications. Read as much of Cadillac Tech Tips as you can wade through as well as this forum. Study the Cadillac Technical Archive way up ^^^ in the black bar. Read the sticky posts at the top of any forum of interest. There are new procedures for resealing the halfcase and oil pan.
    The lower end in any unknown used engine is a crapshoot - you have no idea of the maintenance history so you would probably be better off doing a full overhaul nstead of just head gaskets. Now we're talking money - the crank does not get reground: It gets replaced if necessary. Cylinders do not get honed or bored............. this could go on and on, but it's all in the GM service manual for the particular car/year/engine. Some have put a Northstar back together with very little attention to detail - however, I don't recommend a half-assed approach. Do it right or don't even start.
    There are two engine versions, and which parts you need depends on the model of Deville you're buying.
  7. #6
    04GrandAmGT's Avatar
    04GrandAmGT is offline Cadillac Owners Fanatic
    Automobile(s): 2001 DTS, 04 Grand Am GT,07 Cobalt(Dont Judge,My fuel Saver)
    Oct 2012
    Manitoba, Canada
    375
    Re: 1999 Deville Headgasket - head job or total overhaul ?
    Full Stud kit - $549.00
    we do offer a full gasket kit from oil pan to intake gaskets + Coolant crossover gaskets - $449.00
    Main stud kit - $189.00
    all prices include Xpresspost shipping (2-4 Business Days)
    if you have any questions at all call me at 1-888-800-9470 or email info@northstarperformance.com and i will be happy to assist.
    9/10 times the bottom ends of these engines are in well condition to keep using, like Sub says depends on how they serviced it, but you will know as soon as you split that half case how they serviced it by what the bearings look like.
    Need parts for your Northstar Engine? www.northstarperformance.com
    Evrett, Sales Executive of the SureGripô Cylinder Head Stud Kit
  8. #7
    May 2010
    Racine, Wisconsin
    24
    232
    Wel guys the car turned out to be complete junk. Had rust and cracked bumpers, busted windshield and nasty looking interior. And the guy told me it was immaculate....
    But I will be learning the headgasket soon. I have TWO headgaskets I am going to have to replace now.
  9. #8
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,993
    There are plenty out there in excellent condition that just have HG's gone (or as the owners think). For really cheap.
  • You may not post replies
