2002 Deville Overheating after Thermostat replacement
Results 1 to 8 of 8
Northstar Engines and System Technical Discussion Discussion, 2002 Deville Overheating after Thermostat replacement in Cadillac Engine Discussion; Replace thermostat about a month ago and all worked fine, but now it is overheating again. Any thoughts? Help would ...
    JohnV is offline Cadillac Owners Member
    Jun 2014
    3
    Help would be appreciated. Thanks, John
    2manyhotrods's Avatar
    2manyhotrods is offline Cadillac Owners Fanatic
    Automobile(s): 1999 Eldorado ETC coupe.
    Jun 2013
    Massachusetts
    438
    Re: 2002 Deville Overheating after Thermostat replacement
    Air pocket maybe?
    They are a brute to bleed air out of.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Not if the purge line is clear, then they are. Instantly self bleeding. Zero effort required.
    John,
    How hot is it getting when it's "overheating"? Under what conditions is it overheating? Idle? Cruise? When accelerating?
    04GrandAmGT's Avatar
    04GrandAmGT is offline Cadillac Owners Fanatic
    Automobile(s): 2001 DTS, 04 Grand Am GT,07 Cobalt(Dont Judge,My fuel Saver)
    Oct 2012
    Manitoba, Canada
    376
    check purge line if that is free flowing, get a block test done, sounds like early signs of HG.
    Need parts for your Northstar Engine? www.northstarperformance.com
    Evrett, Sales Executive of the SureGrip™ Cylinder Head Stud Kit
    Jun 2014
    3
    One to two lines up on gage while cruising. Will come down to normal if left a idle for a short while, maybe 15 minutes or so.
    Oct 2012
    Manitoba, Canada
    376
    sounds like you might be lucky and just have a clogged purge line. theres a hollow bolt that the purge line clamps to thats normally the point where it gets clogged
    arctic_man's Avatar
    arctic_man is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Deville
    Jun 2008
    The Sticks, MN
    27
    264
    Quote Originally Posted by 04GrandAmGT View Post
    To check the purge line: Start the car, remove the rad cap, and then remove the purge mine where it connects to the coolant tank. Coolant should be flowing from the line you disconnected. If not, it is clogged somewhere. Per Everett, the hollow bolt the purge line connects to is typically the culprit. Take some compressed air and flow it out. It should start flowing again. If that does not work, you can take the appropriate sized drill bit, and carefully drill the hole out to clear the crap.
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,997
    Did you put the air bleed hole on the thermostat pointing at 12'o clock position?
  11. Remove Advertisements
