Special tool for Northstar water pump drive pulley - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 46
Like Tree1Likes
Northstar Engines and System Technical Discussion Discussion, Special tool for Northstar water pump drive pulley in Cadillac Engine Discussion; I'm tryin to get my valve cover off of my 99 seville and everything is free besides when I go ...
  1. #31
    ndl2s is offline Cadillac Owners Member
    Automobile(s): 1999 SLS
    Jun 2014
    None
    53
    Valve cover stuck on 99 sls
    I'm tryin to get my valve cover off of my 99 seville and everything is free besides when I go to lift it and slide the camshaft extension out it gets stuck and won't slide over the extension for the waterpump pulley
    Post merged from identical thread.
  2. #32
    Jun 2014
    None
    53
    Re: Special tool for Northstar water pump drive pulley
    Quote Originally Posted by oldstuff View Post
    Have you tried rolling the engine over a little. you may have a cam lobe interfering with it.
    Dave
    Just gave it a shot no go
  3. #33
    STS-Fan's Avatar
    STS-Fan is offline Cadillac Owners Member
    Automobile(s): 1989 Seville STS C&C Build
    Feb 2014
    Leicester, MA
    37
    90
    Quote Originally Posted by ndl2s View Post
    Thanks for the reply I have everything out of the way the cover seems to get wedged by something under it on the right side near where I took the pully off when I lift the left side over the chain then I can't slide it
    There's nothing else on that side of the motor only thing under the valve cover is the 2 camshafts. there is a camshaft cap near the end there where the shaft comes out but that should have no bearing on the valve cover removal. any chance you can shoot a quick video of the issue and post it onto YouTube so we can see visually what your having an issue with - just post the link here. Is the valve cover completely loose before you go to move it can you move it feely before you go to slide it over?
    http://cliff.hostkansas.com/pffimage...inder_head.jpg
  5. #34
    Jun 2014
    None
    53
    Quote Originally Posted by STS-Fan View Post
    Yea I'll make a video in the morning, but yea I can wobble it all around before I try to lift it over the chain side and slide it
    My valve cover doesn't really look like that one
  6. #35
    STS-Fan's Avatar
    Feb 2014
    Leicester, MA
    37
    90
    What do you mean that's a Northstar valve cover in the removal photos
  7. #36
    Jun 2014
    None
    53
    I'm just sayin mines more a diff little, let me pull up a picture....image.jpg
  8. #37
    STS-Fan's Avatar
    Feb 2014
    Leicester, MA
    37
    90
    same thing without the beauty cover over the top the directions are the same
  9. #38
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    56,590
    If that's his picture and those are his yellow arrows, it's a pre-2000 engine, but there should be no difference in the removal sequence.
    I wonder if the spark plugs need to be removed.
    Post #1 says he has a 1999 Deville.
  10. #39
    oldstuff is offline Cadillac Owners Fanatic
    Automobile(s): 66 convert-93-96-97-97-99 Eldorados
    Nov 2013
    McCleary Wa.
    81
    460
    Good question. I can't imagine anyone trying to remove the cover without removing the plugs.
    Shure wouldn't go endways with them in.
    Dave
    Quote Originally Posted by Submariner409 View Post
  11. #40
    Jun 2014
    None
    53
    I did not snap this shot, found it online... My cam covers just the same molding as the one pictured (pre2000)... Of course u need to pull out the plug wires, but the actual plugs set down that there's no way it's gettin stuck on them.
    I don't see the word deville in this whole thing till u said it lol
  12. #41
    Nov 2013
    McCleary Wa.
    81
    460
    With the cam sticking through the cover there is no way you can raise it enough to clear the plugs so you can move it endways. SHEESH!!The plugs sit in a tube that is cast into the cover.
    Dave
  13. #42
    arctic_man's Avatar
    arctic_man is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Deville
    Jun 2008
    The Sticks, MN
    27
    266
    Re: Valve cover stuck on 99 sls
    That one is a bit tricky. Do you have that gasket off on the end of cover? Remove that, it may give you a bit of extra room.
    If I recall, when I took mine off, I lifted it up a tiny bit, then slid it over to remove it. There isn't much room to do it, as it is a tight fit, but I can assure you I did not have force anything. Kinda like a rubics cube, it will come off one way or the other with little force.
    This post merged from identical thread.
  14. #43
    Feb 2006
    56,590
    Re: Special tool " "
    ndl2s, Your identical cam cover question merged with your original thread on the same problem. Please do not post the same problems in two identical threads.
  15. #44
    Jun 2014
    None
    53
    Sorry won't do it again but honestly it solved my problem and now the cam coves off
    Quote Originally Posted by arctic_man View Post
    All I had to do was unbolt the front motor mount and lift the motor a little came right off! Thanks for the reply
  16. #45
    Nov 2013
    McCleary Wa.
    81
    460
    Yeh after you removed the sparkplugs.
    Dave
  17. Remove Advertisements
