Special tool for Northstar water pump drive pulley - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 46
Like Tree1Likes
Northstar Engines and System Technical Discussion Discussion, Special tool for Northstar water pump drive pulley in Cadillac Engine Discussion; Post #14 The removal procedure assumes that everything is out of the way of the cam cover - hoses, belts, ...
  1. #16
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,148
    Re: Special tool for Northstar water pump drive pulley
    Post #14
    The removal procedure assumes that everything is out of the way of the cam cover - hoses, belts, pulleys, belt tensioner, everything.
  2. #17
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    As posted, you'll have to remove (and replace) the camshaft seal.
  3. #18
    ndl2s is offline Cadillac Owners Member
    Automobile(s): 1999 SLS
    Jun 2014
    None
    53
    How do I "work" the valve cover off
    Valve covers wedged on there do I have to jack the front side of the motor??!?
  5. #19
    Feb 2006
    57,148
    Is everything - EVERYTHING - out of the way ? All hoses, radiator cover, belt tensioner, w/p belt, cover, everything.
    No, you should not need to lift the engine - and if you do, you'll need jackstands to hold the car and then remove the front motor mount.
  6. #20
    Jun 2014
    None
    53
    I can lift the cover all the way off on the one side (over the chain on the inside and everything) then when I go to slide it off the rod the covers not moving at all
  7. #21
    Feb 2006
    57,148
    Have you removed the cam extension oil seal as shown in Post #14 ?
    Buy a new one for the replacement process. The original WILL leak like a sieve.
  8. #22
    Jun 2014
    None
    53
    Quote Originally Posted by Submariner409 View Post
    Yea that's off tis still stuck
  9. #23
    Feb 2006
    57,148
    Hmmm............ MC, you shed any light on this one ??
  10. #24
    oldstuff is offline Cadillac Owners Fanatic
    Automobile(s): 66 convert-93-96-97-97-99 Eldorados
    Nov 2013
    McCleary Wa.
    81
    460
    It takes the removing of the bolted on cam seal to gain enough clearance to work it off the end of the camshaft "That rod"
    Dave
    Quote Originally Posted by ndl2s View Post
  11. #25
    Feb 2006
    57,148
    He did that since Post #14 and #17, verified in #22
    Can you work the cover back into its original as-installed location and begin again with the oil seal removed ?
  12. #26
    Nov 2013
    McCleary Wa.
    81
    460
    I see where you told him but didn't see any response where he did it. All he can talk about is having his head unbolted and that darn "rod"
    I think he needs to bolt his head back on so he can think and do as suggested and remove the cover.
    Dave
  13. #27
    Jun 2014
    None
    53
    I can put the cover on its stuck though when I try to lift it off like post #16 but it will not slide off
  14. #28
    STS-Fan's Avatar
    STS-Fan is offline Cadillac Owners Member
    Automobile(s): 1989 Seville STS C&C Build
    Feb 2014
    Leicester, MA
    37
    90
    If the cam cover is off how about - Is the belt tensioner for the water pump still in place? Did you get the valve cover bolt that's hidden on that side? Is it getting stuck on the oil dipstick or upper radiator hose? Those are the initial items in that area that come to mind that you might be fighting against.
  15. #29
    Jun 2014
    None
    53
    Quote Originally Posted by STS-Fan View Post
    Thanks for the reply I have everything out of the way the cover seems to get wedged by something under it on the right side near where I took the pully off when I lift the left side over the chain then I can't slide it
  16. #30
    Nov 2013
    McCleary Wa.
    81
    460
    Have you tried rolling the engine over a little. you may have a cam lobe interfering with it.
    Dave
  17. Remove Advertisements
