2000 sls high idle
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, 2000 sls high idle in Cadillac Engine Discussion; All of a sudden my idle stays at about 1100 to 1200 rpm. Might jump up to 1400 than back ...
    jrsample is offline Cadillac Owners Member
    Oct 2005
    2000 sls high idle
    than back to 1200. Car only has 44,000 miles. Could this be a memory thing, or sensor?
    mcowden is offline Cadillac Owners Connoisseur
    Jun 2003
    1,164
    Re: 2000 sls high idle
    Quote Originally Posted by jrsample
    It could be a bad idle air control valve. Could also be a vacuum leak. Check for codes and let us know. My guess is the IAC valve if nothing else changed. You should post this in the Northstar section. I would move it, but I don't have mod privileges here...
    Mike
    Krashed989's Avatar
    Krashed989 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, and a 99 ETC
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    I agree with Mcowden, either the IAC valve or insufficient vaccum mainly to the FPR (ie. a vaccum leak).
    Oct 2005
    Thanks for the quick responce. Beats me what's going on, things are back to normal.
    The next day we drove the car -things were fine. I'll still keep your ideas in mind.
    Thanks again!
  7. Remove Advertisements
