95 ETC Overheating Sometimes??
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, 95 ETC Overheating Sometimes?? in Cadillac Engine Discussion; I have a 95 ETC and it gives me the "STOP ENGINE - OVERHEAT" warning on and off. Sometimes I ...
    jbiz is offline Cadillac Owners Member
    Sep 2005
    1
    I have a 95 ETC and it gives me the "STOP ENGINE - OVERHEAT" warning on and off. Sometimes I go a day or 2 w/o seeing it then somedays it keeps coming up over and over, causing my car to not accelerate and stall when stopped. Its not losing coolant or leaking oil? I tried replacing most of the minor parts, Tstat, plugs, etc.
    Any feedback would be a blessing - THX in adv
    mcowden is offline Cadillac Owners Connoisseur
    Jun 2003
    1,164
    Re: 95 ETC Overheating Sometimes??
    Quote Originally Posted by jbiz
    Several options - collapsing hose during high flow rates, stuck water pump belt tensioner (needs to be flexed and lubed), bad surge tank cap, plugged radiator or heater core... If you use the Search feature above, you will find lots and lots of information about overheating issues.
    Mike
    68
    82,082
    Don't forget to check for plugged purge line.
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    What does the DIC say the actual temperature is when that happens? Should be in the set of readouts you see when you hit the info button.
  7. Remove Advertisements
