Developed an engine whine... what is it?
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 43
Northstar Engines and System Technical Discussion Discussion, Developed an engine whine... what is it? in Cadillac Engine Discussion; My car (98 Deville base) started making a strange whine from under the hood in the past 2000 miles or ...
    wingman0121 is offline Cadillac Owners Member
    Automobile(s): 1998 Deville, 2007 DTS
    Apr 2014
    37
    My car (98 Deville base) started making a strange whine from under the hood in the past 2000 miles or less, it is present when the engine starts and the pitch of the whine changes with the engine RPM, sort of sounds like people who installed gear drive on a small block to drive their camshafts but not nearly as loud. The car has 218k miles. I took it to a car shop and the guy listened it with a stethoscope and he said the noise is coming from inside the engine. The car runs fine and it didn't change any driving characteristics this whole time, the oil is clean and I don't see any silver particles. Another shop said my power steering pump is going bad but I don't hear any weird noise or have problem turning the wheel while parked. I read about checking the pulleys by taking off the belt but my 1/2" ratchet is too short and there aren't enough room for my hands to move it.
    In the past 1000 miles or so I noticed a clacking noise from under the hood when I first start in the morning, it sounds a lot like the engine is knocking but goes away as soon as I drive off. It doesn't do it every time but I've never heard that sound before in the past 8 years, again the engine didn't lose power or anything abnormal when it does make that sound. I read about carbon buildup and I do give it the foot at least once every few days so it shouldn't be carbon.
    In any case I'm a little worried since I'm about to go on a 2000-mile round trip to visit my grandmother.
    rodnok01's Avatar
    Feb 2012
    NC
    6,651
    Re: Developed an engine whine... what is it?
    Could be a idler/tensioner pulley or alt or related, could be WP tensioner pulley. Take stethoscope and listen to each pulley and item. You can get cheap serp belt tool at Harbor Freight.
    Apr 2014
    37
    I went to the shop and had them take the belt off and the engine still makes that noise while running, the whine sounds like it is coming from under the intake manifold.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,199
    WHICH belt ?? There are two - the main accessory drive serpentine belt and the water pump drive belt at the rear (driver's) end of the engine.
    Under the intake manifold is either a vacuum leak or a broken/faulty Bendix drive on the starter pinion gear.
    In the front (passenger) end it (discounting the p/s pump) would be one of 3 timing chains, 4 cam sprockets, chain tensioners/guides/slippers.
    68
    82,062
    Quote Originally Posted by wingman0121 View Post
    Could it be a vacuum leak from the manifold over pressurization relief valve seal behind the P/S pump?
    The other possibility (if the noise is from the other end) is the starter not disengaging from the flywheel.
    Apr 2014
    37
    Quote Originally Posted by Submariner409 View Post
    The accessory belt. I hope it isn't anything inside the engine because most car shops in my area HATES working on Northstar engines and opening one means they'll want to charge a bunch of money.
    How do I go about checking the vacuum leak? As far as the starter not disengaging from the flywheel, does that mean the starter motor is being driven by the engine while the car's running?
    rodnok01's Avatar
    Feb 2012
    NC
    6,651
    I would take the WP belt off and check again. that little pulley makes a racket when wearing out(seizing more like it) and is very easy to remove using 1/4 inch rachet.
    68
    82,062
    Spray some Brakleen or TB cleaner into the tunnel behind the P/S pump. If you have a vacuum leak the RPM will increase.
    Yes
    Apr 2014
    37
    Quote Originally Posted by rodnok01 View Post
    I'm pretty sure it isn't the water pump since the noise isn't coming from that area, but since the car had its water pump replaced almost 100,000 miles ago (AC Delco part) I will check it tomorrow.
    Yes
    I sprayed some carb cleaner at the relief valve and the engine rpm didn't change. As far as checking the starter, since electric motors produce electricity while being turned by an external source is there a place in the fusebox or wiring harness where I can hook up a multimeter and see if the starter is producing power?
    68
    82,062
    I don't know about that. I'd just listen in the starter vicinity with a stethoscope. That should pretty much pin point the starter if that's the cause.
    Apr 2014
    37
    I'll get a set of stethoscope tomorrow, I assume ones for medical purposes works just fine? If the starter is really not disengaging at all then wouldn't it be broken after the many WOTs I did in the past 1000 miles? The car still starts just fine and its startup behavior is the same like before. I felt the clacking noise in the gas pedal last night while accelerating, again the car didn't act any different and the noise went away after a few seconds.
    rodnok01's Avatar
    Feb 2012
    NC
    6,651
    They sell a cheapo mechanics stethoscope with a metal rod on the end so you can pinpoint it on a bearing or area.
    Apr 2014
    37
    Oh I didn't realize that it's a bit different after looking at harbor freight, I will visit auto parts store tomorrow and see.
  16. #14
    68
    82,062
    Either buy a mechanics stethoscope or convert a medical one like I did by removing the chest pad and replacing it with a copper tube.
    I'm not sure how long a starter motor can survive like that.
  17. #15
    Apr 2014
    37
    Okay will do. I suppose a last ditch effort to see if the starter is not disengaging without taking off the intake manifold is by turning the key to start when the engine's already running? If it makes that awful noise then that should mean it's disengaging correctly.
  18. Remove Advertisements
