limp mode..now misfire
Results 1 to 12 of 12
Northstar Engines and System Technical Discussion Discussion, limp mode..now misfire in Cadillac Engine Discussion; Hey everyone My '99 eldo 'Y' overheated and went into limp mode, said turn off engine, change oil now. I ...
    eldoedwardo is offline Cadillac Owners Fanatic
    Automobile(s): '99 Eldorado coupe
    Mar 2011
    KCMO
    62
    161
    Hey everyone
    I fixed the leak, changed the oil, and the p0300 engine misfire detected won't stay cleared.
    I took the 41-950's out and freshened them up but it still has the code because it still has a
    rough idle. Is there anything else that needs to be done after limp mode has been activated?
    There are codes for each cylinder but only the 0300 shows up. any suggestions will be much
    appreciated, thanks Ed
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    The inboard scanner will only display P0300, not P0301-P0308. Have the codes pulled at a parts store.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,909
    Re: limp mode..now misfire
    Camel mode = overheated engine. Drops cylinders to lower temperature of combustion and move "cool" air through the dropped cylinders.
    Limp mode = engine controls and ignition default to a fixed timing of 10 degrees BTDC due to some ignition or major emissions failure: Limp home.
    Spark plug wires (AC Delco $110 set), coil checks/cleaning, ICM cleaning, ICM ground wire terminal cleaning. Wires/coils/plugs connected exactly as shown.
    Mar 2011
    KCMO
    62
    161
    Thanks everyone, camel mode it is. Is there a specific way to check the coils? I have new plugs 41-950's (not installed yet), wires are 10k miles old. It is my own fault by not turning it off sooner. I hope it is not damaged too bad.
    thanks Ed
    Feb 2006
    55,909
    You probably have done NO damage to anything. Probably didn't need an oil change either, but that's a GM safety recommendation.
    Disassemble the ignition system, dismount the coils, make everything squeaky clean and check the ICM itself for cracks. Make sure that ground wire is properly connected and that the terminals are clean and tight.
    The plugs come pre-gapped to .050". Pick up a small packet of anti-seize at a parts store and use a toothpick to work a dab into the first (bottom) 3 threads of each plug. Tighten to about 13 lb/ft. I like to use a smear of silicone dielectric ignition grease around the inside of each plug and coil wire boot.
    EDIT: Where was the coolant leak ?? Any chance that coolant got onto/into a CKP or CMP electrical connector ? (CranKshaft Position, CaMshaft Position)................The diagram.
    Ranger is online now Cadillac Owners Member
    68
    81,924
    Did it spray coolant all over the engine or just out the over flow hose and down to the ground? Or did it not overflow at all?
    Mar 2011
    KCMO
    62
    161
    the short hose in front and below the throttle body sprayed upward then overheated real bad and steamed
    the engine fully. It wasn't dripping, but it was wet.
    thanks everyone
    Feb 2006
    55,909
    You can remove (eliminate) the throttlebody hoses entirely and replace the remaining purge line with a length of proper sized reinforced fuel hose - from the hollow bolt/nipple directly to the surge tank nipple. Use small band clamps and be careful - that surge tank is old, brittle polyethylene plastic. (If it has not been replaced, it's on its last legs anyway.)
    68
    81,924
    If the entire engine was wet and you still have a misfire, try spraying all the ignition contacts with WD40. Pull each plug wire and spray the inside of the boots (both ends). Pull the coils and spray both the top & bottom contacts (clean them with emery cloth if they show any signs of oxidation). Likewise the ICM contacts.
    Mar 2011
    KCMO
    62
    161
    Thanks, how does one check a coil /coils for good,bad, or weak? Im cleaning the coil pack now. later Ed
    68
    81,924
    Take the car to AZ or AAMCO or such and have them run the codes for you. As you can see by Sub's diagram, each coil services 2 cylinders. Their scanners (unlike out onboard diagnostics) will tell you which cylinders are misfiring as MC said in post #2. If you find 2 cylinders on the same coil misfiring, it's a pretty sure bet that the problem is the coil.
    http://www.ehow.com/how_7863891_test...coil-pack.html
    Another possibility might be the ICM.
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
    You can remove wires from plugs one at a time - see which one (s) do not affect the idle speed. A bad injector, or bad connection to injector, will also cause a misfire and rough idle that mimics an ignition misfire
  15. Remove Advertisements
