2005 STS Camshaft Sensor Location? V8 4.6 engine
Results 1 to 11 of 11
Northstar Engines and System Technical Discussion Discussion, 2005 STS Camshaft Sensor Location? V8 4.6 engine in Cadillac Engine Discussion; Does anyone have a diagram or photo of where the camshaft sensor of a 2005 Cadillac sts v8 4.6 engine ...
    candy0815 is offline Cadillac Owners Member
    Automobile(s): 2005 Cadillac Sts
    May 2014
    Does anyone have a diagram or photo of where the camshaft sensor of a 2005 Cadillac sts v8 4.6 engine is at? Please help!!!
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,910
    Re: 2005 STS Camshaft Sensor Location? V8 4.6 engine
    The CMP (CaMshaft Position sensor - the Acronyms sticky ^^) is bolted to the front of the right cylinder head directly in front of the exhaust cam sprocket. If you suspect that it is faulty, a connector and wiring check should be the first order of business.
    In this drawing the engine is partially disassembled .....................
    04GrandAmGT's Avatar
    04GrandAmGT is offline Cadillac Owners Fanatic
    Automobile(s): 2001 DTS, 04 Grand Am GT,07 Cobalt(Dont Judge,My fuel Saver)
    Oct 2012
    Manitoba, Canada
    376
    Quote Originally Posted by Submariner409 View Post
    he has RWD Northstar, is it still the same? cause i know when they updated the FWD in 2006 the cam sensor got moved to the intake cam.
    Need parts for your Northstar Engine? www.northstarperformance.com
    Evrett, Sales Executive of the SureGrip™ Cylinder Head Stud Kit
    Feb 2006
    55,910
    Yeah, quick trigger finger. In any case, the CMP reads a cam sprocket pulse.
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,998
    It's at the camshaft position actuator solenoid housing. Visible with the beauty cover off.
    May 2014
    Ok thank you for the info!
    dawgy2219 is offline Cadillac Owners Member
    Automobile(s): sts
    Jun 2010
    18
    Does anyone know about how much the dealer charges to reprogram the CPS after a self install? I heard this needs to be done in order to operate properly.
    jacobj is offline Cadillac Owners Member
    Automobile(s): 94 el dorado
    Apr 2014
    26
    Which one is camshaft sensor in picture ?
    Apr 2014
    26
    Quote Originally Posted by maeng9981 View Post
    Which one is CPS? Left or right?
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,998
    There are 4 camshaft position sensors on a RWD. So you are seeing two camshaft position sensors in the picture. The upper one is the intake side, and the lower one is the exhaust side.
    20grand's Avatar
    20grand is offline Cadillac Owners Fanatic
    Automobile(s): 2001 STS
    May 2014
    Omaha, Ne
    30
    296
    Does anyone know which is A and which is B?
  14. Remove Advertisements
