Found used NS, need advice.....
Results 1 to 6 of 6
Northstar Engines and System Technical Discussion Discussion, Found used NS, need advice..... in Cadillac Engine Discussion; I located a used NS ('99 I think) that had an engine fire on top. They said that they would ...
    Quadrasteer is offline Cadillac Owners Fanatic
    167
    I located a used NS ('99 I think) that had an engine fire on top. They said that they would visually check for a head gskt. leak and give me a 30 day warranty. The price is $1200. + $350. shipping. Do you think it's a big risk?? The seller has an excellent reputation and I have bought from them before. Should I have them check anything else to see if it had a gasket or oil leak?
    Feb 2004
    FL
    2,250
    Re: Found used NS, need advice.....
    That's a pretty high price, are they local? The engine fire isn't that big of a deal, depending on when it was caught. I've seen engine fires absolutely melt metal parts. Are they giving you replacement intake, fuel rail, injectors, knock sensor, starter, wiring, etc??
    I bought my engine for $800. Shipping was $300 (ouch). 6x,000 miles, nothing wrong with it.
    167
    No, they're not including any replacement parts. Where did you get yours from?
    Feb 2004
    FL
    2,250
    Junkyard I found via ebay...
    Is it going into a 93-99 caddy? Hotrod? What? The 2000 below will work in a hotrod with an aftermarket computer... The 94 will work in any 93-99 caddy with a swap of the intake manifold for 95+...
    Here's a 2000 engine/trans
    Here's a 94 engine/trans
    You could also check car-part.com for northstars in your state (so you could inspect/hear it run/pick it up yourself)
    blunted is offline Cadillac Owners Enthusiast
    May 2004
    NYC
    585
    Quote Originally Posted by Quadrasteer
    Hmm.. I would think it's impossible to "visually check for a headgasket leak". Sounds like they may be purposely playing on words there. Also for that kind of money, I definetly think you could find a better deal with a better warranty.. shop around is my advice.
    nota is offline Cadillac Owners Member
    Feb 2005
    miami
    67
    10
    I would want a compression test and a leakdown test
    that WILL tell if the head gasket is good
  9. Remove Advertisements
