93 Eldorado
Results 1 to 14 of 14
Northstar Engines and System Technical Discussion Discussion, 93 Eldorado in Cadillac Engine Discussion; I have a 4.6L Northstar; it will not run at constant RPM at idle; periodically speeds up at idle stopped ...
    Dave Day's Avatar
    Dave Day is offline Cadillac Owners Member
    Sep 2005
    93 Eldorado
    I have a 4.6L Northstar; it will not run at constant RPM at idle; periodically speeds up at idle stopped in traffic and hard to brake; dealer says a bad ignition module but I have my doubts considering operating characteristics; almost indicative of bad gas (water)...anyone experienced this??
    Traction control system disabled with TO73 and PO93 codes. Starts rough until TCS Disable appears in IPC...
    68
    81,740
    Re: 93 Eldorado
    I'd first suspect and inspect the IAC (idle air control) valve on the side of the TB. Next, clean the TB if that hasn't been done in a while. Then check for vacuum leaks.
    JC316 is offline Cadillac Owners Connoisseur
    Mar 2005
    DFW Texas
    30
    1,406
    Re: 93 Eldorado
    Maybe the Idle Speed Control motor. It is located right under the cruise control module.
  5. #4
    68
    81,740
    Re: 93 Eldorado
    4.9 uses an ISC motor. The Northstar does not. It uses an ISC valve that meters bypass air around the throttle plate to control idle speed.
  6. #5
    eagleworks4u's Avatar
    eagleworks4u is offline Cadillac Owners Member
    Automobile(s): 1994 Eldorado Touring
    Nov 2004
    Ft Laud Fl
    58
    Re: 93 Eldorado
    Check your codes for a possible map sensor problem codes p031,p071,p095. I thought my fuel pump was bad and it just was the map sensor under the intake manifold. Car runs perfect now
  7. #6
    Mar 2005
    DFW Texas
    30
    1,406
    Re: 93 Eldorado
    Then what is that motor that is right under the cruise control? Autozone lists an idle speed control motor for a 4.6 in a 95 seville. What ever that thing is, it was causing my throttle to jump around.
  8. #7
    peteski is offline Cadillac Owners Enthusiast
    Automobile(s): 85 Eldo Biarritz
    Dec 2003
    Northeast USA
    808
    Re: 93 Eldorado
    Ranger,
    93 N* Engine does use an ISC motor. I know, I own one. Yes, it is the motor under cruise control servo. It's plunger touches the throttle lever and controls idle speed.
    Peteski
  9. #8
    Krashed989's Avatar
    Krashed989 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, and a 99 ETC
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    Re: 93 Eldorado
    T073-----PCM - EBTCM/EBCM Pulse Width Modulation Signal Fault
    P093 (E093)-----Traction control system signals were not received by PCM
    Check your connections going to your EBTCM (Electronic Brake and Traction Control Module). The module is located in front of the tranny. Its easier to see it with the air filter box out of the way. There should be a few brake lines going into it and a large wiring harness. After you make sure the connection is tight, clear the codes and see if they come back after a test drive.
    The codes have nothing to do with your idle speed issue. Follow the other guys instructions on that, I think they pretty much said it all already.
    OHH yeah, by the way,
  10. #9
    68
    81,740
    Re: 93 Eldorado
    Quote Originally Posted by peteski
    Ranger,
    Peteski
    Well I be dipped. Just when you think you know what your talking about. I guess they must have switched in '95 with the redesigned intake. Sorry for the misinformation.
  11. #10
    Dec 2003
    Northeast USA
    808
    Re: 93 Eldorado
    I think that you are correct Ranger.
    Peteski
  12. #11
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    Re: 93 Eldorado
    My 95 has an ISC motor. At least I could swear it does. Will check tomorrow when it's light out. I know it's a 95+ motor with the one piece intake manifold but it would be interesting to check the engine vin against the car's vin since there's junkyard writing on the front cam cover. I know I've seen it around here, but for the life of me I can't seem to find where the engine vin is located - anyone?
  13. #12
    Dec 2003
    Northeast USA
    808
    Re: 93 Eldorado
    Don't know where the VIN is.
    But I thought that when they redesigned the intake and started to use the MAF sensor, they also got rid of ISC. But I have a 93 Eldo, so I'm not sure.
    Peteski
  14. #13
    Dave Day's Avatar
    Sep 2005
    Re: 93 Eldorado
    Quote Originally Posted by Dave Day
    My 93 is a 4.6L, VIN 9, and it does have an idle speed motor. I just replaced it. Motor cost about $175.00 and is platinum coated with traces of gold!!! Spindle was gooked up and appeared not to respond properly on idle runaway.
    However, it didn't solve my idle problem but I think I also have ignition control module problems
  15. #14
    68
    81,740
    Re: 93 Eldorado
    Did you adjust it after installing it?
  16. Remove Advertisements
