new radiator, now engine overheats
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, new radiator, now engine overheats in Cadillac Engine Discussion; I just perchased a new radiator for my 94 sls. when I installed it, the engine overheated. it seems like ...
    starfox86's Avatar
    starfox86 is offline Cadillac Owners Fanatic
    Automobile(s): 1998 deville, 2000 sls, 2006 CTS-V, 2001 STS, 2007 STS V8
    Feb 2005
    WISCO
    440
    I just perchased a new radiator for my 94 sls. when I installed it, the engine overheated. it seems like the upper radiator hose isnt getting much pressure and the bottom is getting alot. my old radiator was holding a temp of 200-230, i think it was a little clogged because it would get to as much as 234 sitting still , but not any higher. i replaced it because there was a leak where the trans fluid would go in. so, is there something i needed to do after installing it , besides flushing the system? now, i dont have the tablets in , I was going to get them after i installed it.
    VinnyT's Avatar
    VinnyT is offline Cadillac Owners Fanatic
    Automobile(s): 1998 Deville
    Aug 2005
    Va
    43
    230
    Re: new radiator, now engine overheats
    Sounds like your thermostat is stuck closed. Did you check it when you changed the radiator? Is the top hose warm and the bottom hot? If it is, it is the stat.
    Dadillac's Avatar
    Dadillac is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 Mazda3 S GT Hatchback 2013 Kia Optima SXL
    Nov 2004
    Woodbridge NJ
    51
    2,817
    It is very easy to install a thermostat the wrong way. Make sure that the stat has the spring end facing in towards the engine block, not the radiator.
    Don
    terrible one's Avatar
    terrible one is offline Banned
    Automobile(s): 1976 Eldorado project
    May 2005
    El Dorado, Arkansas
    26
    1,631
    I'm going to agree with everyone else, and say it was the stat. Was it replaced along with the radiator? If so, I'm thinking you didn't install it right. If it wasn't, it could be a bad t-stat
  7. Remove Advertisements
