Unable to communicate with the console cluster
Results 1 to 8 of 8
Northstar Engines and System Technical Discussion Discussion, Unable to communicate with the console cluster in Cadillac Engine Discussion; Hi everyone , My 2001 deville was parked for a while and the battery went dead. I jump started it, ...
    Alifard is offline Cadillac Owners Fanatic
    Automobile(s): 2001 DHS
    Apr 2014
    221
    Hi everyone ,
    My 2001 deville was parked for a while and the battery went dead. I jump started it, the first time my instrument cluster was blank. On a second jump , I Found My Console Cluster Lit up with (((ABS))) (((Airbag))) and the (((Battery Light))). My Display would not read out percentages of gas used, Oil Life, ETC the Words were all There, But no numbers or results. My mechanic hooked it up to his computer and it was giving him a code and a Message saying (((Unable to communicate with the console cluster))) Has anyone had this issue before or may be able to advise?
    68
    81,926
    Re: Unable to communicate with the console cluster
    Start by pulling your own codes (DTC's). See the DTC Sticky if you need help. Post them AND their definitions.
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,998
    If your car was fine before sitting, most likely your battery is long gone. A jump start with a flat-dead battery would be no use. These cars are heavy on electronics and will requite quite a lot of juice, and the dead battery might be working as a load, not properly supplying the boosted electricity to the modules. Check your battery voltage with a multimeter (without boosting it beforehand) and replace it if it's any below 12V.
    eldoedwardo is offline Cadillac Owners Fanatic
    Automobile(s): '99 Eldorado coupe
    Mar 2011
    KCMO
    62
    161
    to anyone that read this, do not run your car with a dead battery. It will suck the life out your alternator like a stargate
    alien....Ed
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,370
    Quote Originally Posted by eldoedwardo View Post
    alien....Ed
    =========================== 100% TRUE
    68
    81,926
    You NEVER want to use the alternator to charge a dead battery.
    ocgltd's Avatar
    ocgltd is offline Cadillac Owners Fanatic
    Automobile(s): 2001 STS
    Oct 2008
    London Ontario
    300
    Did you ever solve this? See one of my older posts "dashboards gone wild". Replace the battery and that may just fix it for you. (At least test the battery).
    Apr 2014
    221
    Quote Originally Posted by ocgltd View Post
    That's exactly what it was...a battery change solved it all
  11. Remove Advertisements
