changing PCValve on 94 eldorado
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, changing PCValve on 94 eldorado in Cadillac Engine Discussion; i've had my cadillac for 3 years and never changed the pcvalve. How often should this be changed? If its ...
    erictg26 is offline Cadillac Owners Member
    Apr 2004
    17
    If its dirty or clogged would it affect the cars performance?
    is it easy to change?
    where is it located?
    Eldyfig's Avatar
    Eldyfig is offline Cadillac Owners Connoisseur
    Automobile(s): 13 Challenger RT, 11 CTS Coupe Premium, 94 Eldorado (RIP)
    Jan 2003
    Folkston, GA
    1,306
    Re: changing PCValve on 94 eldorado
    If it is plugged, it needs to be changed. They are really inexpensive and they are simple to change out. Leaning in over the passenger side fender, look at the left side of engine just pass the highest point the serpentine belt travels. The PCV valve is inserted into the top of the left side cam cover. There is a small diameter black tubing coming out the top of it that runs toward the back of the engine (towards the driver's side).
