SJ - API oil
Results 1 to 7 of 7
Northstar Engines and System Technical Discussion Discussion, SJ - API oil in Cadillac Engine Discussion; Hello Everyone, No OIL WAR, please stand down! Ok with that over, I have changed brands (still good quality) of ...
    eldoedwardo is offline Cadillac Owners Fanatic
    Automobile(s): '99 Eldorado coupe
    Mar 2011
    KCMO
    62
    161
    SJ - API oil
    Hello Everyone,
    of oil. Only because of the SJ requirement for '99 N*. Most of other oil say's they meet SN and
    previous requirements. How can it meet previous requirements when zinc is being phased out
    or lowered? My N* uses a little oil and I clean the rings occasionally by the down hill low range
    slow down.
    I don't have a problem with the different brand (I prefer another) but I don't want to put
    anything in without assurance it is suitable for a flat tappet N*
    I have read Joe Gibbs, Knieze report, and various threads here but still feel a bit leary about
    the 'meets previous requirements' claim.
    P.S. Oh yah, no problems with the before and aft o2's so I would say the cat isn't damaged.
    Changed b2s1 running great..22 mpg at avg. speed of 38mph! Cool by me. closing in on a left
    strut? squeak...?
    If it's runnin' good,
    shut the hood,
    and cruse....later Ed
    68
    81,897
    Re: SJ - API oil
    Quote Originally Posted by eldoedwardo View Post
    or lowered?
    BTSOM!
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,858
    Re: SJ - API oil
    Here's a fairly new API table. You might find one with the current SN in a Google search.
    http://www.api.org/certification-pro...GLISH_2013.pdf
    JoeTahoe is offline Cadillac Owners Enthusiast
    Automobile(s): 2001 GMC SLT, Malibu LTZ, 99 STS studded with NP
    Jul 2010
    Central, NY
    48
    502
    Re: SJ - API oil
    i would use a diesel oil as they still use zinc. I personally use Rottella 10w30 witch is very easy to find in my area
    Feb 2006
    55,858
    Re: SJ - API oil
    There is an old, persistent, totally false wive's tale that says not to use diesel specification oils in automotive gasoline engines. For info straight from the horse's mouth (The American Petroleum Institute), read this .....
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,998
    Re: SJ - API oil
    I use the Rotella T5 Synthetic Blend 10W30 for the Deville.
    Mar 2011
    KCMO
    62
    161
    Re: SJ - API oil
    thanks Everyone,
    Sub, that chart on your attachment indicated sj and sl had the same numbers : .110 zinc/.100
    phosphorous. Some of the sites indicated that the diesel oil (I used 10-30 I think T5 for quite awhile) has more
    contaminates that an sj engine( pre 2000) should be asked and handle. The new chart as I mentioned showing no
    difference in zinc/phos in the sl oil may open my choice up a little.
    To all the N* owners that responded thank you very much for your time and effort also.
    I think the N* must have grown stronger in its ability to control its oil immunities for newer api/certs
    ED
  10. Remove Advertisements
