pull engine from the top in sections ?
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, pull engine from the top in sections ? in Cadillac Engine Discussion; Has anyone pulled the heads in the car to make room to pull the block from the top. Really dont ...
    sts96 is offline Cadillac Owners Fanatic
    May 2004
    333
    Has anyone pulled the heads in the car to make room to pull the block from the top. Really dont want to drop power train the heads have to come off any way.( leaking head gasket). 1997 DeVille 125k sts96
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    Re: pull engine from the top in sections ?
    Most of us are into seville's. The deville? Why pull the heads first? Won't it come out with the heads on? It comes out of the STS that way.
    Personally, it's easier to drop the cradle.
    Dooman's Avatar
    Dooman is offline Cadillac Owners Enthusiast
    Automobile(s): 1999 Black and Tan STS
    Mar 2004
    753
    My mechanic lifted the engine from the tranny out the top of my 99 STS to do my headgaskets..
    Sep 2003
    Arizona
    3,531
    It can be done that way but it was designed to come out the bottom. If you are doing it I recommend the cradle dropping method.
  7. Remove Advertisements
