Northstar question!
Results 1 to 10 of 10
Northstar Engines and System Technical Discussion Discussion, Northstar question! in Cadillac Engine Discussion; I recently purchased a Fleetwood Limited, a 98. I love this car. It's used, had one owner, has 38,000 miles. ...
    FrankyCorleone is offline Cadillac Owners Member
    Aug 2005
    21
    Northstar question!
    If anyone has more information on Fleetwood Limiteds, let me know. All I have is the brochure and information regarding it. I'd still like to know more.
    Anyway, now to my question...
    I started hearing a small sound, almost like a belt squeeling, going off and on. The sound started getting worse, almost like a bearing.(I immediatly thought alternator.) When I first start the vehicle, now, the sound doesn't exist. The longer I drive it, the worse it gets. I was sitting parked in a alley, idling, the sound got almost unbearable to the point where it was something we had to talk over. Speak louder than normal. The sound almost sounds like a tension or alternator. The sound changes though, that's what I don't understnad. It also doesn't start, or do it all the time.
    If anyone had any similar problems, let me know.
    VinnyT's Avatar
    VinnyT is offline Cadillac Owners Fanatic
    Automobile(s): 1998 Deville
    Aug 2005
    Va
    43
    230
    Re: Northstar question!
    It does sound like an alternator or tensioner bearing, or A/C compressor. Those bearings can go too. Is it a grinding or a squealing?
    Aug 2005
    21
    More of a grinding/whining.
    Feb 2004
    FL
    2,250
    I had a horrible squeeking coming from the tensioner... I replaced it, and now it's 90% better. For some reason, I still get random squeeks. I haven't isolated that cause, but it may be the alternator bearing, since everything else is brand new.
    There's only so many things that can squeak or grind, so you can try to isolate it with a piece of hose held up to your ear, with the other end (carefully) placed near the various pullies.
    69
    82,393
    Also don't forget the water pump drive belt tensioner on the rear (drivers sdie) of the engine.
    Aug 2005
    21
    Definately not water pump. coming from front of motor.
    Mark Bunds's Avatar
    Mark Bunds is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Seville STS
    Jul 2005
    Baytown, Texas
    57
    187
    Quote Originally Posted by FrankyCorleone
    Check the electric cooling fans. I had one that was making a terrible noise until I replaced it.
    coffeebreak1 is offline Cadillac Owners Member
    Jan 2004
    north carolina
    50
    32
    check ac pully i had same problem (i had to replace ac compressor).
    Rick94STS's Avatar
    Rick94STS is offline Cadillac Owners Member
    Apr 2005
    New Jersey
    31
    I had same problem, turned out to be the pully bolted directly to the block right next to the tensioner pully.
    good luck...
    mcowden is offline Cadillac Owners Connoisseur
    Jun 2003
    1,164
    Quote Originally Posted by Rick94STS
    good luck...
    That would be the idler pulley. The bearings in the tensioner and idler don't last forever. I've replaced both on my '96. Same for the A/C compressor.
    Mike
  13. Remove Advertisements
