Guide to replace water pump...
Results 1 to 12 of 12
Northstar Engines and System Technical Discussion Discussion, Guide to replace water pump... in Cadillac Engine Discussion; Hi, Im trying to compose a comprehensive guide to N* water pump replacement. There are some great threads about this ...
    highonchai's Avatar
    highonchai is offline Cadillac Owners Fanatic
    Automobile(s): '85 Seville Commemorative, '69 Sedan deVille, '06 CTS Sport
    Feb 2004
    Lansing, MI
    31
    424
    Hi, Im trying to compose a comprehensive guide to N* water pump replacement. There are some great threads about this out there, but none seem to address all the issues in one place.
    Please help me with a list of usefull tools and items to have and parts to replace with new.
    1. New water pump/ impeller
    2. Specialty tool to remove and install pump
    3. Gasket sealer
    4. New Upper and Lower radiator hoses
    5. New WP Drive belt
    6. New heater hoses: Heater to pipe 1, heater to pipe 2, and tee to reservoir
    7....
    Anything im missing? a detailed set of procedure instructions would be paramount in this, so any help there would be great. Thanks!
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    Re: Guide to replace water pump...
    I don't have a instruction list, but after you do it consider writing it up and putting it in the tech tips.
    highonchai's Avatar
    Feb 2004
    Lansing, MI
    31
    424
    Good call. Question for those who have done it: '96 SLS: how do you drain the coolant from the lower hose without getting coolant all over everything???
    Eldyfig's Avatar
    Eldyfig is offline Cadillac Owners Connoisseur
    Automobile(s): 13 Challenger RT, 11 CTS Coupe Premium, 94 Eldorado (RIP)
    Jan 2003
    Folkston, GA
    1,306
    Drain the radiator using the drain valve.
    Mark Bunds's Avatar
    Mark Bunds is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Seville STS
    Jul 2005
    Baytown, Texas
    56
    187
    I posted these instructions on my site. They are actually for a 2001 STS but are pretty much universal. The drawings are for identification of locations and parts and do not necessarily follow the numbered instructions.
    http://www.alliedintermedia.com/Cadillac/wpr.htm
    highonchai's Avatar
    Feb 2004
    Lansing, MI
    31
    424
    Where will i find the Drain Valve on the radiator?? thanks
    highonchai's Avatar
    Feb 2004
    Lansing, MI
    31
    424
    Found, drivers side, bottom of radiator, below lower coolant hose and trans hose... NEARLY IMPOSSIBLE to get to and/ or turn... any tips?? About to pull lower rad. hose and call it good.
    Sep 2003
    Arizona
    3,531
    We just pull the hose, but it depends on where you are working (hate a mess like that in the garage). It does make a mess, even with pans to try to catch it.
    68
    82,064
    When I did my daughters '99 I took a piece of dowl rod (3/4" or 1", I can't recall) and simply cut a slot in the end of it. That worked very nicely as a tool to reach up and engage the drain plug to loosen and retighten.
    All you need to do is remove the intake ducting, then remove the drive belt shield. Use a 1/4" drive breaker bar or ratchet to move the tensioner and remove the drive belt. Remove the front cover, then use the special socket to remove the impeller. Remember it is a cam lock, not threaded so it only takes about 1/8 - 1/4 turn to remove and install. Clockwise to remove and counter clockwise to install. Here is a picture of a water pump socket I made. http://www.geocities.com/grandolfo. You can buy cheap stamped steel ones for $15 - $20. I have heard some say that they slip. A good Snap-on will run about $75 but it is machined and much beefier much like the one I made. I have not had to replace mine yet. I am sure that is because I took the time to make the socket, but I have heard others say to be sure to lube the "O" ring seal before instalation.
    ratherbriding99's Avatar
    ratherbriding99 is offline Cadillac Owners Member
    Oct 2004
    michigan
    32
    how did you make your tool? Where can you get the cheap sockets? With gas prices and me driving 50 miles of back roads a day i don't have any extra money(gas prices and all).
    I turned the drain plug with my hands with the hose in place. I just pushed it with my thumb and then my pointer finger.
    68
    82,064
    I made the tool on a bench lathe I have. I actually cut the teeth on a power hack saw by hand as I did not have a dove tail cutter for my mill. Then used a 1/2" drive socket cut down and welded to the back for the drive.
    The link below has a cheap one. You can see the difference even in this picture. http://thetoolwarehouse.net/shop/TTW161.html
    highonchai's Avatar
    Feb 2004
    Lansing, MI
    31
    424
    i got my tool at autozone, gave them $30 for their brand new loaner specialty tool. seems mighty beefy to me, and didnt dream of slipping.
  15. Remove Advertisements
