overheating
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 21
Northstar Engines and System Technical Discussion Discussion, overheating in Cadillac Engine Discussion; What is the normal coolent tempature for a northstar engine before the fans turn on? (cadillac 97)...
    Mago is offline Cadillac Owners Member
    Jun 2005
    Questionoverheating
    R-Caddy's Avatar
    R-Caddy is offline Cadillac Owners Enthusiast
    Automobile(s): 2 1997 Cateras: black&ocean green
    Jul 2005
    Savannah, GA
    32
    698
    Re: overheating
    northstar I think thermostat starts to open at about 198 degrees and the fan come on at about 220 I think... But the temperature gauge is going to show it quite hot
    Vesicant's Avatar
    Vesicant is offline Cadillac Owners Connoisseur
    Automobile(s): None :(
    Nov 2003
    Jacksonville, FL
    2,703
    Re: overheating
    Moved.... from the Catera section...
    68
    82,076
    Re: overheating
    They seem to vary a bit but mine runs about 206 during the summer and 213 during the winter +/- a couple of degrees.
    Eldyfig's Avatar
    Eldyfig is offline Cadillac Owners Connoisseur
    Automobile(s): 13 Challenger RT, 11 CTS Coupe Premium, 94 Eldorado (RIP)
    Jan 2003
    Folkston, GA
    1,306
    Re: overheating
    Fans turn on when the temp reaches 225 or whenever the a/c is running.
    Rick94STS's Avatar
    Rick94STS is offline Cadillac Owners Member
    Apr 2005
    New Jersey
    31
    Re: overheating
    Is there a way to make the fans turn on earlier??
    68
    82,076
    Re: overheating
    Not that I am aware of unless you hot wire them to run all the time.
    Rick94STS's Avatar
    Apr 2005
    New Jersey
    31
    Re: overheating
    Quote Originally Posted by Ranger
    Yeah I thought of splicing in a toggle switch to ground and mounting it under the dash to turn on the fans when I want, not sure if I want to go that way, was hoping there was a more clean way of doing it.
    thanks
    68
    82,076
    Re: overheating
    Why do you want to force them on? If the system is not operating as designed then I think you'd be far better off finding the problem and correcting it rather than crutching it.
    kaps52 is offline Cadillac Owners Member
    Aug 2005
    8
    Re: overheating
    most gm fan switches/ecm turn on the fans around 230 plus you always want the engine to run at normal temps between 200- 230 for emissions reasons, also the engine parts expand if the temp does not reach normal temp premature engine wear could occur
    VinnyT's Avatar
    VinnyT is offline Cadillac Owners Fanatic
    Automobile(s): 1998 Deville
    Aug 2005
    Va
    43
    230
    Re: overheating
    I still think 200-220 is TOO hot. Engines like cooler temps. I used to work on Chevy 350's, Buick 3.8, even Audi 5 cylinders and they all benefited with lower temps. I've been debating changing the T-stat to 180. The coolant temp sensor will decide when the fans cut on. I'm looking for one of those now. One that will turn on at 195. I've know people to run 160 stats in cars, which is TOO low. I cannot see anything negative in running a 180 stat. Lower temps would probably help the head gasket issue as well. Just my $.02.
    Sep 2003
    Metro ATL
    4,854
    Re: overheating
    Quote Originally Posted by Mago
    Normal coolant temp. for my '98 is approximately 200 degrees at idle with no air flow across the radiator. With A/C off, engine idle, no air flow, my fans come on (at low speed) at 220 degrees and shut off when temp. drops to 214 degrees. Just like the sytem was designed and built to do.
    With any amount of air flow (vehicle moving > 15 MPH), the coolant temperature sits right at the wet thermostat operating point (again, approximately 200 degrees).
    A 50/50 mix of water/ethelyne glycol at 15 PSI has a boiling point of 265 degrees. I don't have a problem with the coolant temp. reaching 220 degrees at idle in traffic. One of the benefits of running a little higher temp. is the vaporization of potentially nasty fluids in the crankcase oil supply, again, as designed.
    144,000 trouble-free miles and counting.
    Rick94STS's Avatar
    Apr 2005
    New Jersey
    31
    Re: overheating
    I would like to have the option of turning them on at will, I am having no problems at all with my coolant system at this moment but the milege is at 135K right now and I am concerned with that so I would like to run it cooler in the summer months. I agree with others that 225 to 230 degrees is just "TOO HOT" for any engine to run no matter what it was designed to do, especially on a high milege vehicle.
    I was told the LS1 motor in my Vette will run better at high temps, but that means more emission friendly better, not high performance long life better. With that said I have a 160 stat and fans programmed to turn on early which gives me that warm and fuzzy.
    VinnyT - if you ever locate that temp sensor that will turn the fans on earlier for the N* please let me know
    thanks
  16. #14
    mcowden is offline Cadillac Owners Connoisseur
    Jun 2003
    1,164
    Re: overheating
    Quote Originally Posted by Rick94STS
    thanks
    Not sure why you think you need to re-engineer something that works just fine for the vast majority of owners. Exactly why is 230 "too hot?" What damage or other negative effects do you think will happen? How do you refute the evidence that most of these cars never have any heat-related problems? Are you saying that if everybody put a lower temperature thermostat in their car that the engine would last longer for everyone?
    Mike
  17. #15
    68
    82,076
    Re: overheating
    "I would like to have the option of turning them on at will, I am having no problems at all with my coolant system at this moment but the milege is at 135K right now and I am concerned with that so I would like to run it cooler in the summer months. I agree with others that 225 to 230 degrees is just "TOO HOT" for any engine to run no matter what it was designed to do, especially on a high milege vehicle."
    Well, if it makes you feel better, go ahead. If that where true, how can you explain the many 200-300K Northstars that are running around with no problems? I really think you are worrying needlessly.
  18. Remove Advertisements
