Deville engine swaps and differences
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, Deville engine swaps and differences in Cadillac Engine Discussion; Have a 2000 Deville used engine with with a 9 vin number that I want to put in a 2001 ...
    mariojacksonjr is offline Cadillac Owners Member
    Sep 2012
    7
    Have a 2000 Deville used engine with with a 9 vin number that I want to put in a 2001 Deville made for a motor with a Y vin number. My question is will this motor work with this car and it's computer with no problems or major modifications?
    68
    82,070
    Re: Need help
    No, at least not like it's supposed to. The engine, PCM and transmission final drive ratio are all mated together.
    The only Deville made for a VIN 9 is the DTS. Is that what you are talking about? The base Deville and the DHS use the VIN Y. Stick with the proper engine.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,237
    Re: Deville engine swaps and differences
    The two engines use different cams, different powertrain calibrations (different PCMs), and different final drive ratios. The swap MIGHT work, but there will be all sorts of nagging problems.
    Please read the Northstar engine interchange thread in the stickys just above this thread.
    Thread cleaned up and title changed to be a bit more descriptive. (We ALL "need help" !)
    68
    82,070
    Oops! There goes another punch in my dumbshit card.
  7. Remove Advertisements
