bad smell and smoke
Results 1 to 6 of 6
Northstar Engines and System Technical Discussion Discussion, bad smell and smoke in Cadillac Engine Discussion; there is a bad smell which smell of a mix between burnt plastic and coolant coming from under the hood ...
    phenom01515 is offline Cadillac Owners Member
    Mar 2005
    23
    bad smell and smoke
    there is a bad smell which smell of a mix between burnt plastic and coolant coming from under the hood of my 95 ETC. i popped the hood to find some faint smoke or steam rising from the back of the motor, like coming from under the distributor area. what would this be? please help
    Kev's Avatar
    Kev
    Kev is offline Cadillac Owners 10000+ Posts
    Automobile(s): 1989 Sedan DeVille is now just a fond memory ....
    Aug 2004
    Left Coast (Central)
    57
    10,423
    Re: bad smell and smoke
    My first guess would be a leak in one of the heater hoses. There are two hoses that run from the water pump and intake manifold to your heater core. It is likely that one of them has developed a leak. It's a minor repair but should be done ASAP. Never let a coolant leak go on for very long at all.
    Mar 2005
    23
    would this be smoking and such even if im not using the heater?
    Kev's Avatar
    Kev
    Aug 2004
    57
    10,423
    Quote Originally Posted by phenom01515
    Yes, it would smoke profusely if the leak is in the heater hose from the intake to the heater core as it passes over the right exhaust manifold.
    Mar 2005
    23
    ill try to look down there.
    mcowden is offline Cadillac Owners Connoisseur
    Jun 2003
    1,164
    It is probably easier to look "up" there. If you get the thing in the air, you will be able to see more easily what is leaking from underneath. You'll need a light.
    Mike
  9. Remove Advertisements
