AIR pump on '99
Results 1 to 9 of 9
Northstar Engines and System Technical Discussion Discussion, AIR pump on '99 in Cadillac Engine Discussion; Hello Everyone, I read a post here about at start up there was a rough idle for about 30/45 seconds ...
    eldoedwardo is offline Cadillac Owners Fanatic
    Automobile(s): '99 Eldorado coupe
    Mar 2011
    KCMO
    63
    161
    AIR pump on '99
    Hello Everyone,
    I read a post here about at start up there was a rough idle for about 30/45 seconds and the
    reply was that by pump, air is forced into the Cat on start-up and that made it smooth. correct me if not
    quite on it. I checked Rock and Alldata and did not see any info. Does a '99 eldo w/ Y have this?
    That's what mine does. In the AM I'll start it, gently slip it in gear and let it roll out of the
    garage, then neutral until it clears the garage (because it stinks), by the time all that happens
    its
    idling smoothly. I don't believe its anything drastic but I would like it to operate properly. I'm
    getting 21mpg at average speed of 29mph so there shouldn't be much wrong.
    Could a faulty B2S1 be responsible? It is only about 2 yrs old when I clear the code it stays off
    until I really jump on the gas.
    Josie my shepherd and I like cruising in our Eldo
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    The AIR pump does pump air into the cat during a cold start. It's to help the cat reach operating temp quicker. It has nothing to do with how the car runs/idles.
    Have you pulled your codes recently?
    Are you having to add coolant?
    69
    82,190
    Re: AIR pump on '99
    Have you checked for a leaky FPR?
    Mar 2011
    KCMO
    63
    161
    Re: AIR pump on '99
    Hey Ranger, no I have not checked that , but I will shortly after you explain to me what it is, please!
    I'm just learnin' things left and right this week, keep it coming I've got room..
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    56,634
    Re: AIR pump on '99
    In any forum of interest, always study the sticky posts just above these threads - FPR ?? The Acronyms sticky.
    Begin by going to the top black bar and study the entire Cadillac Technical Archive. Then study the stickys in Discussions, Item Specific; Cadillac Tech Tips. The engine, cooling system, gauge and fan stickys in Engines; Northstar.
    Find a real GM/Helm service manual set on eBay. Haynes or Chilton are far, far too generic.
    Learn about DTCs, RPOs, TSBs and if available, read the owner's manual - twice - or download one. (Those stickys again !)
    That's enough homework for today. More tomorrow ...........
    69
    82,190
    Re: AIR pump on '99
    The FPR (Fuel Pressure Regulator) is a small canister on the fuel rail with a vacuum line on top. Simply pull the vacuum line (red arrow) at idle and look for any sign of fuel at the nipple. There should be none.
    Yours may be a nylon rail (yellow arrow) like this. If not, it will be black steel.
    Mar 2011
    KCMO
    63
    161
    Re: AIR pump on '99
    Thank you MoistCabbage for your response and the lession, Does my '99 even have a pump? I've looked in rock and
    alldata and could not locate any. If it does not it is one less thing to worry about.
    Ranger thanks for the pic, it took the uncertainity out of where and what it looks like.
    Sub, thank you for reminding me of the sticky's..you can send me homework anytime...I----must----learn----more!
    helm.com is next
    Feb 2006
    56,634
    Re: AIR pump on '99
    You have a few extra bucks ??? For instant gratification take out a multi-year subscription to www.alldatadiy.com - it's the GM service manuals plus so darn much more that you need a course in how to find it all. Several of us use it.
    For starters, in addition to being the service manual, it has all RPOs, TSBs, Recalls, labor times, warranty labor times, original parts pricing and diagnostic trees for YOUR car.
    When someone posts "Look at the oil consumption TSB !" - it's there. "What's the RPO for my radio ?" - it's there.
    Mar 2011
    KCMO
    63
    161
    Re: AIR pump on '99
    Thanks Sub, The extra money would certainly be worth it for all that other info...thanks everyone ....Ed
  12. Remove Advertisements
