Cost of rebuilding transmission?
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, Cost of rebuilding transmission? in Cadillac Engine Discussion; Question, how much does it typically cost to get the transmission rebuillt for a 95 sls with a northstar engine ...
    resa156888 is offline Cadillac Owners Member
    Jun 2005
    Jacksonville, Florida
    11
    Question, how much does it typically cost to get the transmission rebuillt for a 95 sls with a northstar engine from a transmission shop?
    mcowden is offline Cadillac Owners Connoisseur
    Jun 2003
    1,164
    Re: Cost of rebuilding transmission?
    That's going to depend on exactly what they do during the rebuild. Do you have a detailed quote to share that we can work with?
    Mike
    addison_ii's Avatar
    addison_ii is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 Sedan Deville
    Mar 2005
    Twin Cities, Minnesota
    35
    2,146
    When I thought my trans was toast, I was quoted $2000 dollars. However there is place out of Arizona that sells them for $1,050. Here's there website and contact info.
    http://www.phoenixhardparts.com/
    Phone:
    623.936.1500
    800.399.5540
    Fax:
    623.936.1148
    Headquarters:
    7310 W Roosevelt
    Suite # 26
    Phoenix, AZ 85043
    Eldyfig's Avatar
    Eldyfig is offline Cadillac Owners Connoisseur
    Automobile(s): 13 Challenger RT, 11 CTS Coupe Premium, 94 Eldorado (RIP)
    Jan 2003
    Folkston, GA
    1,306
    Darn, it has been a while since my eldo trans was rebuilt. I had a spun bushing which caused a good leak from the side of the trans. Leak was located up in between the small space above the side of the oil pan. Point being, the trans had to be dropped. I had the trans rebuilt including all the electronic sensors. I figured it was down and out of the car and I had read about problems with the speed sensors, so I figured it best to do it. I didn't do the torque convertor. Total cost, if I can remember correctly came to about $2500. This job was done by a custom shop, not one of the corparate ripoffs like aamco or cottman. I am fully satisfied with the job done. I haven't had any problems since the work was done a little over 2 years ago. Same guy did my TH400 trans from my Olds for $700. Again, I was completely satisfied.
  7. Remove Advertisements
