Compass reads incorrect sometimes?
Results 1 to 7 of 7
Northstar Engines and System Technical Discussion Discussion, Compass reads incorrect sometimes? in Cadillac Engine Discussion; Wondering if any of you have a similar problem. my compass on my rear view mirror sometimes reads just "C" ...
    1fastSTS is offline Cadillac Owners Fanatic
    Mar 2005
    NY
    125
    my compass on my rear view mirror sometimes reads just "C" , then once in a while it kicks into the normal SW, N, S, E mode. it seems to work then not work and just be on "C" im wondering if theres a setting thats incorrect, or its just on its last life ...
    whats needed to fix this thing , im assuming its just a simple plug and play item i need to purchase from th dealer?
    any info , thanks
    Sep 2003
    Metro ATL
    4,854
    Re: Compass reads incorrect sometimes?
    Find an empty parking lot and make several slow, continuous 360 degree turns. Stay as far as possible from any ferrous metal structures.
    Spyder's Avatar
    Spyder is offline Cadillac Owners Master
    Automobile(s): None now...1972 Challenger=my pride and joy.
    May 2004
    Sonoma Co, CA
    34
    5,688
    What will that do? Is that a way to reset it or just to diagnose it or what?
    Sep 2003
    Metro ATL
    4,854
    Reset comes close. Or zero-out the confusion factor.
    mtflight's Avatar
    mtflight is offline Cadillac Owners Connoisseur
    Automobile(s): 1999 White Diamond ETC
    Jan 2005
    Dallas, TX
    2,538
    There are setup instructions in your owner's manual. Maybe re-setting it to the right area (there are several areas geographically) would help.
    Mar 2005
    NY
    125
    ok ill try that and see what happens, if nothing changes ill see what the dealer hasd to say about replacing the item, of course it will be expensive :/
    Sep 2003
    Metro ATL
    4,854
    Try positive thinking....
  10. Remove Advertisements
