2001 Deville oil distribution manifold plate seal leak
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By 960deville
Northstar Engines and System Technical Discussion Discussion, 2001 Deville oil distribution manifold plate seal leak in Cadillac Engine Discussion; Help......completed insert install and reseal on 01 Deville and after 4000 miles observed sealant being pushed out at oil pan ...
    960deville is offline Cadillac Owners Member
    Automobile(s): Deville
    Aug 2013
    7
    Help......completed insert install and reseal on 01 Deville and after 4000 miles observed sealant being pushed out at oil pan seam. Could it be a faulty PCV valve?
    97EldoCoupe likes this.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    What does this have to do with pistons?
    It looks like too much sealant was used initially, hard to tell if it's being pushed out or not.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,919
    Re: 2001 Deville flat or domed pistons
    Let's move this to its own thread. Pistons ??? transmission ?
    Looks like the oil distribution manifold seal has given up. You're supposed to install a new distribution plate .................. MC might be right. Way too much goop. If it oozed out like that outside before curing, what's now in the oil pump pickup screen ?
    68
    81,928
    Quote Originally Posted by Submariner409 View Post
    Isn't that what happened to ChazGlenn and ended up costing him a motor due to oil starvation?
    97EldoCoupe's Avatar
    97EldoCoupe is offline Cadillac Owners Connoisseur
    Automobile(s): 97 ETC x2, 04 GXP, 04 STS x2, 97 ESC, 99 Deville, 05 SRX
    Mar 2007
    London, Ontario and Winkler MB
    31
    2,618
    Re: 2001 Deville oil distribution manifold plate seal leak
    Is that pan cracked? That sealant oozing out looks like it oozed out of a hairline crack. Just my $.05 (no pennies in this country anymore, nickel is the smallest denomination).
    The SKRL cast pans have a very weak flange, doesn't take much to crack them.
    Did you use a gasket and sealant for the oil pan? Or just sealant?
    I always use a new pan gasket (GM OEM, not Fel-Pro) with a thin bead of GM sealant on the outside edge. The gasket prevents any sealant from squeezing inside the engine, and offers one sealing interface. The GM sealant serves as the second sealing interface.
    98eldo32v's Avatar
    98eldo32v is offline Cadillac Owners Connoisseur
    Automobile(s): 98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
    Apr 2010
    51
    2,126
    Whoever did that re-seal used WAAAYYY too much sealant.
    Wow.......
    Better for it to be oozing out, hopefully it hasn't oozed IN.......
    Feb 2006
    55,919
    Quote Originally Posted by 97EldoCoupe View Post
    That begs the question: Why, after time and 4000 miles, has the sealant (RTV) not cured ?
    Does anyone have a link to the GM TSB that outlines the new reseal procedure ?
    Aug 2013
    7
    Thanks guys for the coaching….I probably did screw up with the reseal and used too much sealant. I tried to follow the bead height of .117 inches on mating surfaces per the SB. The local Cadillac garage Northstar mechanic told me that he typically uses approximately 2 tubes of the GM 88861417 2.65 oz sealant for a reseal. I used a little bit less than that so I thought I was good. With the engine on a stand, I used degreaser and alcohol on all sealing surfaces until it met the white glove test. Oh well……
    Anyway, once I got the Deville on the road I would periodically put the car on my lift and check for leaks. Just recently I noticed the sealant being pushed out at one spot on the corner of the pan. Almost as if the crankcase was being pressurized. I pulled the dipstick and installed a pressure gauge but saw nothing significant at idle. I did not check it above idle yet. I have pushed the engine rpm’s a couple times while driving. I’m not sure what’s going on…..
  11. Remove Advertisements
