2001 Deville N* Spark plug boots questions
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, 2001 Deville N* Spark plug boots questions in Cadillac Engine Discussion; I am changing the spark plugs and plug boots on my '01 Deville Base. I have a few questions: Which ...
    mikeymorehead is offline Cadillac Owners Member
    Automobile(s): 2001 Deville Base
    Dec 2004
    NE Texas
    45
    20
    Question2001 Deville N* Spark plug boots questions
    1. Which end do I put the contact spring into?
    2. When I put he contact spring in, do I need to push it through the narrow part of the boot or will it push through on its own?
    3. Do I need to use dielectric grease on the spring ends?
    I haven't been able to find much info concerning this and this is the first time I have been exposed to coil packs and spark plug boots.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,870
    Re: 2001 Deville N* Spark plug boots questions
    Plug boots, spring centered internally ........
    Dec 2004
    NE Texas
    45
    20
    Thanks Sub. Should I use some kind of lubricant like dielectric grease or silicone spray?
    Feb 2006
    55,870
    Most new boots already have a dab of dielectric in the lower tips. A judicious smear in the upper 1/4", where the coil cassette tower sticks in, would hurt nothing.
    If you found one or more plugs with some oil on the metal shell or insulator, that's pretty normal - the O-ring seals in the cam cover wells weep over time. Not a problem.
  7. Remove Advertisements
