Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 64
Thread: Northstar overheating-Repair
  1. #31
    04GrandAmGT's Avatar
    04GrandAmGT is offline Cadillac Owners Fanatic
    Automobile(s): 2001 DTS, 04 Grand Am GT,07 Cobalt(Dont Judge,My fuel Saver)
    Oct 2012
    Manitoba, Canada
    375
    Re: Northstar overheating-Repair
    No. Running the A/C should have no effect on the temperature gauge. Mine never leaves 12:00 A/C on or A/C off. 236 is too high. The fact that it goes down when you accelerate leads me to think that there is air in the system.
    possible HG failure again? could have been improper hg job done... you never know.
    Need parts for your Northstar Engine? www.northstarperformance.com
    Evrett, Sales Executive of the SureGripô Cylinder Head Stud Kit
  2. #32
    69
    82,284
    Good point Evrett. Was the HG job done? Where all 20 bolt holes drilled, retapped and inserted or studded?
  3. #33
    gino9's Avatar
    gino9 is offline Cadillac Owners Fanatic
    Automobile(s): Eldorado 4.5 88' & STS 4.6 N* 01'
    Sep 2009
    Oxford,UK
    34
    165
    Purge line...I disconnect hose from bolt (when engine over 12 oclock)and coolant flow with high pressure.After coolant pee..
    All 20 bolt holes was drilled.HG job done,all gasket seals,thermostat,piston ring...Not sure yet how good
    I didn't check yet nipple from surge tank,Maybe there is blocked.What I found,manifold intake take air.
  4. #34
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    NEVER open a cooling system when hot. The correct way to check the purge line is to disconnect it (when cold) from the surge tank nipple, not from the bolt/nipple near the water pump cover. Yes, you can also check the tank nipple for blockage.
    As Evrett,Ranger and I have asked, were the proper inserts or studs used? They didn't use Helicoils, did they?
  5. #35
    gino9's Avatar
    Sep 2009
    Oxford,UK
    34
    165
    Head Bolts are from CCC
    Head bolts are from CCC
  6. #36
    69
    82,284
    OK, questions answered and it seems to have been done correctly.
  7. #37
    Oct 2012
    Manitoba, Canada
    375
    where alignment dowels reinstalled, ccc doesnt have self aligning studs in the upper 4 corners, could have torqued head down not 100% straight would cause instant hg failure again. by the looks of the last picture there was no alignment dowels installed.
    PS - Drilling and tapping with no cylinder protection not recomended but should be fine because from the looks of it they had it completely apart and were ready to wash it, though by the looks of pic 18/23 looks like there are still alum shavings when they reinstalled the pistons, HOPEFULLY they cleaned those out because those could cause serious cylinder damage! but seems like the HG job was done correctly.
  8. #38
    97EldoCoupe's Avatar
    97EldoCoupe is offline Owner of Northstar Performance
    Automobile(s): 97 ETC x2, 04 GXP, 04 STS x2, 97 ESC, 99 Deville, 05 SRX
    Mar 2007
    The Great White North
    31
    2,600
    Gino9-
    Never drill/tap an engine block freehand. There is a reason I sell a fixture plate with my kits, the slightest alignment issues shift the stresses in the block. Take it from someone who has experience, doesn't matter what kind of a threading tap you have- bottoming, taper, spiral flute, etc.... you will NEVER thread a hole completely straight without using a guide of some sort. Anyone who wants to argue this point; come to my shop and we will do some experimenting on this.
    I hope all goes well and that you can get that overheating issue sorted out.
    Wishing you the best.
    -Jake
  9. #39
    gino9's Avatar
    Sep 2009
    Oxford,UK
    34
    165
    Before the HGs were repaired, did you use any stop leak products?
    Not me 'but previous owner.
    Quote Originally Posted by 97EldoCoupe View Post
    Gino9-
    -Jake
    They used own alignment,so didn't drilled freehand.
    So..what next if job was made correctly?
    Radiator?
    I will go check block surge tank now
    I forgot,they give me 6 months warranty to check everything is ok.
  10. #40
    Oct 2012
    Manitoba, Canada
    375
    get a cooling system flush done maybe rad has limited flow from stop leak style products.
  11. #41
    gino9's Avatar
    Sep 2009
    Oxford,UK
    34
    165
    I think before about this but before HG failure was OK.I will do it....OMG
  12. #42
    Mar 2007
    31
    2,600
    Stop leak usually doesn't clog radiators first -
    this is where I have to agree with the usual "check purge line" idea, it is imperative to cooling system operation that the system be free of air.
    Have you done the exhaust gas test after the new build? I hope it is something minor. Nobody wants to do this job over-
  13. #43
    gino9's Avatar
    Sep 2009
    Oxford,UK
    34
    165
    Today I did exhaust gas test.....is ok.Blue colour....what now?
    I found the manifold intake(top right corner) take air and idle is rough.Looks like manifold intake gasket not in correct place or......
  14. #44
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,868
    Here are your intake manifold "gaskets" - 8 formed silicone seals. If you can see any part of one you have problems.
  15. #45
    sts 03's Avatar
    sts 03 is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 sts
    Oct 2011
    d.c metro area
    37
    1,754
    ccc studs come with spring loaded dowel pins ,did you use them on the top bank corners?
  • You may not post replies
