Northstar overheating-Repair - Page 2
Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 16 to 30 of 64
Like Tree12Likes
Northstar Engines and System Technical Discussion Discussion, Northstar overheating-Repair in Cadillac Engine Discussion; If your purge line is clear and you have enough coolant, check your cooling fans for proper operation....
  1. #16
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,998
    Re: Northstar overheating-Repair
  2. #17
    04GrandAmGT's Avatar
    04GrandAmGT is offline Cadillac Owners Fanatic
    Automobile(s): 2001 DTS, 04 Grand Am GT,07 Cobalt(Dont Judge,My fuel Saver)
    Oct 2012
    Manitoba, Canada
    376
    Why does everyone want to blame the poor WP all the time. IF THE WP SPINS, IT'S FINE.
    for some reason when i read that it made me chuckle, like the WP has feelings, but Ranger is right check the purge line, Thermostats are pretty much bullet proof on these engines, but they can go from time to time doubtfull but can, make sure yat idle your purge line has a steady stream of coolant coming through.
    Need parts for your Northstar Engine? www.northstarperformance.com
    Evrett, Sales Executive of the SureGrip™ Cylinder Head Stud Kit
  3. #18
    gino9's Avatar
    gino9 is offline Cadillac Owners Fanatic
    Automobile(s): Eldorado 4.5 88' & STS 4.6 N* 01'
    Sep 2009
    Oxford,UK
    34
    165
    Ok
    How can I check cooling fan?
    Is new Thermostat(old gone)
    My engine was rebulid,new seals,gasket,head stud,piston rings etc.
  5. #19
    Oct 2012
    Manitoba, Canada
    376
    Ranger or Submariner, i forget which one has a nice diagram of the temp gauge and when the fans are supposed to kick in, if you guys could post it, that would be peachy.
  6. #20
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    It's in subs albums.
    Low speed at 224 (or when any A/C function is set).
    High speed at 236.
    Courtesy of Submariner 409:
    04GrandAmGT likes this.
  7. #21
    gino9's Avatar
    Sep 2009
    Oxford,UK
    34
    165
    I seen diagram.
    How You know when cooling fan is on speed 2?
  8. #22
    Sep 2010
    East Boston MA.
    29
    26,325
    It'll sound different than low speed operation.
    I have to backtrack a little. If you're testing fan operation, the car is still together and running. Correct? There's no way somebody diagnosed warped heads without removing them.
    Back to your question. If the car is overheating at idle, low speed fan operation is all it would take to keep it cool. if the fans run, your problem is not cooling fan related.
  9. #23
    68
    81,913
    The cooling fans run anytime the A/C is on, so turn on the A/C (or defroster if it's below 1.6C). The fans should come on.
    Quote Originally Posted by gino9 View Post
    I seen diagram.
    There is no speed 2. I believe the fan speeds are infinite. Somewhat like a dimmer switch.
  10. #24
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,875
    Fans run in SLOW or FAST - 2 speeds.
    SLOW at 224 degrees, FAST at 236 degrees.
    Here's the 2000-2004 fan electrical circuit - SLOW speed is fans relay-set to series operation, FAST is parallel.
    Sound alone will tell you when fans shift to FAST - they move a LOT of air. It's all just above this thread in the fan operation sticky.
  11. #25
    gino9's Avatar
    Sep 2009
    Oxford,UK
    34
    165
    Today I will check purge line...
    Now some picture on my engine
  12. #26
    gino9's Avatar
    Sep 2009
    Oxford,UK
    34
    165
    hi
    Today I tested again engine..
    Without A/C temperature go to 206F and back to 12 clock and again 206F and back to 12 clock(nice)
    With A/C temperature go slowly to 236F and stay there,when accelerate go back to 12 clock and again.....
    When driving always 12 clock.
    When disconnect purge line looks OK.
    Mechanic put in to cooling system GREEN antifreezer.
    Not sure yet but maybe really small leak from radiator.
  13. #27
    68
    81,913
    Looks mean nothing. Does it flow coolant at idle?
    Was it low? If so, how low?
  14. #28
    gino9's Avatar
    Sep 2009
    Oxford,UK
    34
    165
    RANGER my engine was rebulid after HG failure.Now I would like be sure everthing is Ok.
    Yes is flow on purge line...His put green antifreezer.
    I'm not sure about temperature when idle.Should be like that what I wrote above?
    Thx
  15. #29
    Sep 2010
    East Boston MA.
    29
    26,325
    The color of the antifreeze is irrelevant.
    How did you check the purge line flow?
    Was the coolant level low?
    Before the HGs were repaired, did you use any stop leak products?
    The repair did inure inserting or studding the block, correct?
  16. #30
    68
    81,913
    Thx
    No. Running the A/C should have no effect on the temperature gauge. Mine never leaves 12:00 A/C on or A/C off. 236 is too high. The fact that it goes down when you accelerate leads me to think that there is air in the system.
  17. Remove Advertisements
