96 Deville T.b. And Egr Cleaning
Results 1 to 7 of 7
Northstar Engines and System Technical Discussion Discussion, 96 Deville T.b. And Egr Cleaning in Cadillac Engine Discussion; HEY EVERYONE I SEARCHED FOR A WHILE AND COULD FIND A POST FOR A 96 N* INSTRUCTIONS FOR CLEANING OUT ...
    96CADDYDEVILLE's Avatar
    96CADDYDEVILLE is offline Cadillac Owners Fanatic
    Jan 2005
    DELAWARE
    35
    169
    Lightbulb96 Deville T.b. And Egr Cleaning
    HEY EVERYONE I SEARCHED FOR A WHILE AND COULD FIND A POST FOR A 96 N* INSTRUCTIONS FOR CLEANING OUT THE T.B. AND EGR. MY CAR HAS BEEN RUNNING A LIL ROUGH AND HESITATING WHEN COLD. I PLAN ON DOING A TUNE UP THIS WEEKEND IM PRETTY HANDY WITH A WRENCH. BUT IVE BEEN WORKING ON MOPARS ALL MY LIFE AND I JUST NEED A QUICK OVERVIEW OF DISMANTLING AND CLEANING THE EGR AND T.B.
    TIA,
    CHASE
    69
    82,402
    Re: 96 Deville T.b. And Egr Cleaning
    Remove the MAF sensor (black plastic tube) bolted to the TB. Block the throttle plate open. Use an old tooth brush and a rag with carb cleaner and clean the TB bore and throttle plate
    If you haven't had the fuel rail recall done, the EGR will be a little easier to remove as the nylon rail has a little flex. If it has been changed then you'll have to remove the fuel rail to get the EGR off because the fuel rail mount is bolted to the EGR stud.. You'll see what I mean when you get there. Once the EGR is in hand just clean the pintle shaft with carb cleaner so that it moves freely and does not stick. Be sure to hold the EGR upright so the carb cleaner does not run into the can as it will destroy the insulating varnish on the windings and render it inoperative.
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    Quote Originally Posted by Ranger
    Which is the stupidest damn design. It's not like the rail is GOING anywhere without that damn bracket. I sawed through mine and it's frickin 1/8" thick. Overengineered
    Jan 2005
    DELAWARE
    35
    169
    thank you ranger you are both a scholar and a gentlmen.
    Jan 2005
    DELAWARE
    35
    169
    Is The Egr Valve The Like 2" Dia. 3" Tall Thing With The Elec. Conn. On Top Thats Held In By 2 Bolts, Next To The Maf Sensor??? If So I Think I Have The Recall Done Cause It Look To Be Ss Gas Lines Attached To The One Bolt Like You Said.
    69
    82,402
    Yup, you got it.
    Jan 2005
    DELAWARE
    35
    169
    you tha man, cleaned them last night after that n* ate my ratchet adapter and had to turn into a search and rescue mission. hesitated to start back up i guess thats normal though, its fine now.
  10. Remove Advertisements
