very bad coolant leak
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
Northstar Engines and System Technical Discussion Discussion, very bad coolant leak in Cadillac Engine Discussion; hi i have a 2002 Dts i have very bad coolant leak around the water pump area... so bad as ...
    bodonovich is offline Cadillac Owners Member
    Automobile(s): sedan deville 1989
    Mar 2011
    25
    23
    so bad as soon as u pour coolant in the reservoir it comes pouring out..... picture a garden hose a little less pressure
    i have a new water pump cover seal proper one for my cover and new thermostat gasket... also have a new water pump and seal..
    just waiting on my water pump socket to come in the mail..
    but this leak is insane
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Did you have a question?
    Hope that the freeze plug didn't come out of the rear of the head.
    V-swagon's Avatar
    V-swagon is offline Cadillac Owners Fanatic
    Automobile(s): 1985 Fleetwood Brougham, 2002 DTS, 2011 CTS-V wagon
    Aug 2012
    Ohio
    39
    162
    That sucks. It could be the crossover housing gasket. There are several of them that are o-ringed and plastic and it could have gave up if its not the water pump o-ring. Good luck.
    Sep 2010
    East Boston MA.
    29
    26,325
    Yup. Usually, a crossover gasket leak starts off slow though.
    68
    81,897
    Re: very bad coolant leak
    I can't imagine the crossover gasket leaking THAT bad.
    Mar 2011
    25
    23
    I took of the water pump belt cover and the belt is whipping coolant around.... There is coolant on the radiator fans also.... I just can't do anything cause I'm waiting for this damn water pump socket Since dec 7
    V-swagon's Avatar
    Aug 2012
    Ohio
    39
    162
    You can sometimes rent the tool from places like Autozone. Advance Auto Parts, and maybe O'Rielys.
    Mar 2011
    25
    23
    I'm in Vancouver Canada and no one has the socket
    Mar 2011
    25
    23
    i got everything ripped apart except the water pump... seems to be leaking under the water pump housing
    Sep 2010
    East Boston MA.
    29
    26,325
    The water pump housing is the crossover.
    68
    81,897
    Quote Originally Posted by bodonovich View Post
    I wonder if that might not be the WP shaft seal or the internal O ring seal. A flashlight and mirror might give you a better look. I'd hate to see you pull the crossover for nothing. That's a bitch of a job.
    Tailfin's Avatar
    Tailfin is offline Cadillac Owners Enthusiast
    Automobile(s): 1996 Deville Concours
    Jan 2004
    New York (verified rust state)
    34
    803
    I second this motion. The two lower bolts toward the front of the car are a disaster. I used a 1/4" socket, an offset manual wrench, and a regular manual wrench, depending on how far out the bolts were. I suggest just finish the water pump. Make sure that new O-ring is seated. I had to slightly stretch out mine so it would stay in the groove. If the crossover is the problem, you can take the housing off again, and just take the crossover off with the pump--without actually removing the pump itself if you need to do the crossover...which I also agree...seems unlikely.
    Mar 2011
    25
    23
    Im hoping its the water pump... im gonna drive across the border tomorrow to buy that socket from auto zone in bellingham... this mail bs is taking to long
  16. #14
    68
    81,897
    Be ware. The AZ sockets are probably the cheaper Lysle or Astro Pneumatic stamped steel sockets (top one). Look close and you can see the difference in the thickness. Sometimes they work and sometimes they slip off a stubborn WP. The better (more expensive) ones (bottom one) are machined and come with a hold down bracket.
  17. #15
    Mar 2011
    25
    23
    alrite so changed the pump finally... no more leaks anywhere...
    but not the car runs really hot like 1 line below the max temp
  18. Remove Advertisements
