very bad coolant leak - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Northstar Engines and System Technical Discussion Discussion, very bad coolant leak in Cadillac Engine Discussion; Check the purge line (cold engine) to be sure it is clear and flows coolant. I assume you have topped ...
  1. #16
    68
    81,928
    Re: very bad coolant leak
    Check the purge line (cold engine) to be sure it is clear and flows coolant. I assume you have topped off the surge tank and it is about 1/2 full? Remember, when you first start it, the pump may suck it dry. You may have to top it off 2 or 3 times until it stabilizes.
  2. #17
    bodonovich is offline Cadillac Owners Member
    Automobile(s): sedan deville 1989
    Mar 2011
    25
    23
    yup checked it, purge line flows coolant... i guess it is just low on coolant... seemed to be air bubbles in the purge line wasnt a solid stream
  3. #18
    04GrandAmGT's Avatar
    04GrandAmGT is offline Cadillac Owners Fanatic
    Automobile(s): 2001 DTS, 04 Grand Am GT,07 Cobalt(Dont Judge,My fuel Saver)
    Oct 2012
    Manitoba, Canada
    376
    Canadian Tire has them
    Need parts for your Northstar Engine? www.northstarperformance.com
    Evrett, Sales Executive of the SureGrip™ Cylinder Head Stud Kit
