Remove N* eng from top or Pwrtrn out Btm?
Results 1 to 8 of 8
Northstar Engines and System Technical Discussion Discussion, Remove N* eng from top or Pwrtrn out Btm? in Cadillac Engine Discussion; I am preparing to replace the headgaskets on my 97 STS. Can you eperienced guys tell me if it is ...
    air1ren is offline Cadillac Owners Member
    Jun 2005
    13
    I am preparing to replace the headgaskets on my 97 STS. Can you eperienced guys tell me if it is better to pull just the engine out the top or remove the whole powertrain out the bottom? The Caddy manual shows out the top as the "alternate" method.
    Reading thru all the info in these forum's I have not heard anyone say which way seemed the easiest. Has anyone tried both methods?
    Spyder's Avatar
    Spyder is offline Cadillac Owners Master
    Automobile(s): None now...1972 Challenger=my pride and joy.
    May 2004
    Sonoma Co, CA
    34
    5,688
    Re: Remove N* eng from top or Pwrtrn out Btm?
    If you are able to drop it through the bottom, ie, if you have the space and something that can lift the body that high in the air, then I'd recommend going that route...I did mine out the top because of space limitations, and it wasn't really all THAT bad...just don't drink too awful much Old Granddad while you're doing it...We learned that the hard way
    cart69's Avatar
    cart69 is offline Cadillac Owners Fanatic
    Automobile(s): 96STS engine only!! only thing left from my 96 after divorce
    Dec 2004
    Illinois
    36
    150
    i just put mine back in and did it out the bottom, i thought it was pretty easy. just used my engine hoist and a strap to pick the car up from the radiator support. not hard at all just make sure you disconnect everything and take your time pulling it and reinstalling it. the only hard part to me was the darn connectors in the front of the motor behind the exhaust manifold on the front of the car those were super tight to get back on, but do able!!
    where are you located??
    Jun 2005
    13
    I am down in Florida... It sounds like out the bottom is the way to go. I plan on taking some pix as I go and post them after. Thanks to both of you for the advice...
    Spyder's Avatar
    May 2004
    Sonoma Co, CA
    34
    5,688
    No prob...good luck on the project!
    Pjs's Avatar
    Pjs
    Pjs is offline Cadillac Owners Fanatic
    Mar 2004
    Nashville, TN
    367
    I definitely think out the bottom is the quickest way to go. Make sure you have an extra pair of eyes when lifting and dropping the body on the powertrain.
    Jun 2005
    13
    Will do... Thanks!
    greggbruce is offline Cadillac Owners Member
    Automobile(s): 93 sts 90 deville
    Jun 2005
    kansas city
    52
    31
    bottom is WAY easier than top. whole powertrain out, seperate engine from trans, put on engine stand, get busy!!
    do them pan seals and crankcase seals while you got it out if there's any signs of leakage.
  11. Remove Advertisements
