Simple spark plug question - Northstar "tune up"
Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By MoistCabbage
Northstar Engines and System Technical Discussion Discussion, Simple spark plug question - Northstar "tune up" in Cadillac Engine Discussion; Just want to get a feel for what people think of plugs for the Northstar engine. I'm pretty well aware ...
    Tailfin's Avatar
    Tailfin is offline Cadillac Owners Enthusiast
    Automobile(s): 1996 Deville Concours
    Jan 2004
    New York (verified rust state)
    34
    803
    Just want to get a feel for what people think of plugs for the Northstar engine. I'm pretty well aware that on the 4.x engines, it's of no use to use anything fancy, just the Delco platinum plugs. This hold true for the N*? I only ask because this is my second N*, and both have a minor tendency to misfire when it's rained or very damp, so I'm mulling on tune-up products...
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Use only the correct AC Delco plug in the Northstar. They tend to foul anything else.
    maeng9981 likes this.
    68
    82,070
    Re: Simple spark plug question
    A/C Delco 41-950's for your pre-2000 Northstar.
    That is not due to the plugs.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,237
    For the 1996, (or any pre-2000 Northstar) with waste spark ignition, the condition and cleanliness of the ICM, connectors, coils and base contacts and plug wires is the determining factor in performance and occasional missing. ANY moisture that collects or condenses on any of those ignition components will cause a nagging miss. Squeaky clean is the answer, because condensing moisture simply LOVES dirt and scum in an ignition system.
    AC Delco #41-950 plugs for pre-2000 engines. AC Delco plug wiresets seem to have the best-fitting boots.
    Google "gm waste spark ignition systyem". Know that Northstars do NOT like cutesy multiple-electrode boutique spark plugs.
    Use this waste spark diagram to properly connect the coil towers, wires, and plugs - make sure that the ICM ground cable is perfect and tight, clean terminals.
    Tailfin's Avatar
    Jan 2004
    34
    803
    Re: Simple spark plug question - Northstar "tune up"
    Cool thanks. Yeah, I understand what waste spark is...each coil fires both of its plugs every cycle. Guess it was too expensive to have 8 coils LOL. The cleanliness issue certainly makes sense. I'll do the cleaning. These things are simply great for that kind of job
    http://www.widgetsupply.com/product/BCU66.html
    I've gone through many of them :-P.
  8. Remove Advertisements
