Case 1/2 seal Question
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, Case 1/2 seal Question in Cadillac Engine Discussion; Bbob or anybody else that knows for sure. I searched but couldn't find the definate answer. Should you use any ...
    98 Caddy is offline Cadillac Owners Member
    May 2005
    25
    Bbob or anybody else that knows for sure. I searched but couldn't find the definate answer. Should you use any Timeserts in the block when fixing the 1/2 case seal? Does this joint suffer from the same problems that the head gasket suffers from? I am going to pull the motor and seal the case halfs along with the head gaskets and just want to make sure I am doing this right. Any help is appreciated.
    Spyder's Avatar
    Spyder is offline Cadillac Owners Master
    Automobile(s): None now...1972 Challenger=my pride and joy.
    May 2004
    Sonoma Co, CA
    34
    5,688
    Re: Case 1/2 seal Question
    No...there is not nearly the thermal cycling in the case halfs...You shouldn't need to timesert any of those holes at all...
    jjbuckley is offline Cadillac Owners Fanatic
    Dec 2003
    113
    Here is a link to a photo essay of a half case repair, very good stuff.
    http://caddyinfo.onedgesolutions.com/howto/casehalf.htm
    John
    Pjs's Avatar
    Pjs
    Pjs is offline Cadillac Owners Fanatic
    Mar 2004
    Nashville, TN
    367
    I think I'm one of the few that has had to timesert the bottom end of the block. As long as the threads don't strip when you tighten them back up then you don't need to timesert.
  7. Remove Advertisements
