Cylinder head bolt replacement
Results 1 to 11 of 11
Northstar Engines and System Technical Discussion Discussion, Cylinder head bolt replacement in Cadillac Engine Discussion; I believe that I have head bolts that have failed and according to what I have read on the this ...
    jerry23 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Aug 2007
    24
    QuestionCylinder head bolt replacement
    I believe that I have head bolts that have failed and according to what I have read on the this site my coolant loss is the result of coolant leaking into the cylinders because ofthese bolts. My question to the group is if there is a way to replace the bolts without pulling the engine. Doing the job with the engine in place would take much longer but I am in no hurry at this point. Any thoughts? My Seville has 160k miles and is a 99.
    Tailfin's Avatar
    Tailfin is offline Cadillac Owners Enthusiast
    Automobile(s): 1996 Deville Concours
    Jan 2004
    New York (verified rust state)
    34
    803
    Re: Cylinder head bolt replacement
    I just did that...take a look at my thread just below here. Read the whole thing though...I encountered an error in the FSM and in my last post, I specifically mentioned some things regarding your question.
    http://www.cadillacforums.com/forums...ng-n-head.html
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,518
    ...... and read through the sticky posts just above. You'll need the info.
    Inserts from above - yes. Studs, no.
  5. #4
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    28
    26,325
    Short answer - You cannot STUD the block with the engine in place.
    You can INSERT the block with the engine in place, but it's not recommended. It's much more difficult to drill and tap the block with it still in the car. If you mess it up, the engine is junk.
  6. #5
    Aug 2007
    24
    Thank you for the replies. I don't suppose there is a way to raise the engine high enough to get the clearance needed to drill for the new studs?
  7. #6
    Sep 2010
    East Boston MA.
    28
    26,325
    The problem isn't height, it's the clearance between the engine and firewall.
  8. #7
    Aug 2007
    24
    Got it. I will continue to research to make sure I want to do this. Thank You again.
  9. #8
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Jul 2010
    Wyoming
    26
    5,713
    Ideally you'd get an engine hoist, disconnect the subframe/engine/trans from the rest of the car (with a pallet jack underneath the subframe), use the hoist to lift the front end of the car high enough, and then wheel the subframe and contents out from underneath.
    Good luck.
  10. #9
    04GrandAmGT's Avatar
    04GrandAmGT is offline Cadillac Owners Fanatic
    Automobile(s): 2001 DTS, 04 Grand Am GT,07 Cobalt(Dont Judge,My fuel Saver)
    Oct 2012
    Manitoba, Canada
    376
    it is possible to do the studs in the car (we have had a few customers do it) its just the fact you might as well pull the motor because its about the same amount of time and probably a little less effort.
    Need parts for your Northstar Engine? www.northstarperformance.com
    Evrett, Sales Executive of the SureGrip™ Cylinder Head Stud Kit
  11. #10
    JoeTahoe is offline Cadillac Owners Enthusiast
    Automobile(s): 2001 GMC SLT, Malibu LTZ, 99 STS studded with NP
    Jul 2010
    Central, NY
    48
    502
    How in the !!!! Did they stud it in the car. I would love to see pics of that
  12. #11
    Oct 2012
    Manitoba, Canada
    376
    i would have like to too, from what i understood they unbolted the mounts and twisted then whole engine and tranny
  13. Remove Advertisements
