Torquing N* head - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 32
Like Tree5Likes
Northstar Engines and System Technical Discussion Discussion, Torquing N* head in Cadillac Engine Discussion; Humans will never be perfect, we are flawed by design. No matter what we do/ make we may make a ...
  1. #16
    98eldo32v's Avatar
    98eldo32v is offline Cadillac Owners Connoisseur
    Automobile(s): 98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
    Apr 2010
    51
    2,126
    Re: N* Headgasket torquing procedure
    No matter what we do/ make we may make a mistake or flaw because we are not perfect, so nothing we create will be perfect.
    Nature of the beast.....
    Good luck
    Are those bolts torque to yield design?
  2. #17
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    56,619
    Quote Originally Posted by 98eldo32v View Post
    Post #8
    Post #1, Procedure 3.
    EDIT: To further muddy the waters, you can also use a set of ARP studs, nuts and special hardened washers with the NS300L inserts.
  3. #18
    98eldo32v's Avatar
    Apr 2010
    51
    2,126
    Torque yield bolts........DAMN!!!!!
    Another vote for studs.......
  5. #19
    Tailfin's Avatar
    Tailfin is offline Cadillac Owners Enthusiast
    Automobile(s): 1996 Deville Concours
    Jan 2004
    New York (verified rust state)
    34
    803
    Yes yes, have to keep with the law here. Everything has gone wrong :-P. I think the bolts are a bigger concern than the gasket crushing, personally.
    This little article explains them: http://freeasestudyguides.com/a1_4.html
    ..and explains how they're basically screwed after that third pass...the one I did...:-P
    I really think there should be a sticky about that service manual error. That's horrible... I mean if I hadn't stumbled across that post, I would have had a HG failure after all this work and expense, owing to typos. As it is, of course I couldn't stumble across that yesterday...it had to wait until after I torqued my head LOL. Anyone have a use for 20 clean, slightly mal-formed Victor Reinz head bolts? :-D
    EDIT: Oh, in case anyone was wondering, the typo on the M6 (smaller by the timing) bolts is that it's supposed to be 106 lb in
  6. #20
    Feb 2006
    56,619
    Your second thread on this engine problem was in Northstar. I just merged your essentially identical thread from Deville - since we're working on a Northstar engine.
    Racecar ??? ^^^ next post .......
    About the only reason racing engines use studs is because they are taken apart on a very regular basis. The ONLY reason studs are recommended for a Northstar top overhaul is to get away from the torque-to-yield head bolts and failed aluminum block bolt hole threads. If someone wanted to use NS300L inserts or Time BigSerts and good ol' HD head bolts from ARP you could take the heads off a Northstar and replace them to your hearts' content - using only new gaskets. (The trick would be to re-engineer torque values and make sure the head bolts and inserts had fine inner threads for more precise torque control.)
  7. #21
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Jul 2010
    Wyoming
    26
    5,759
    Re: Torquing N* head
    Studs....... to the end.
    BECAUSE RACECAR!!
    98eldo32v likes this.
  8. #22
    Feb 2006
    56,619
    Racecar spelled backwards is ...........
    CadillacLuke24 likes this.
  9. #23
    98eldo32v's Avatar
    Apr 2010
    51
    2,126
    lol......
  10. #24
    69
    82,188
    Quote Originally Posted by Submariner409 View Post
  11. #25
    04GrandAmGT's Avatar
    04GrandAmGT is offline Cadillac Owners Fanatic
    Automobile(s): 2001 DTS, 04 Grand Am GT,07 Cobalt(Dont Judge,My fuel Saver)
    Oct 2012
    Manitoba, Canada
    376
    if worse comes to worse and i believe those inserts are threaded for 5/8 coarse, our studs will still work you will just have to manage getting the insert out and because you have it drilled and tapped, you would just need our SNW kit which is $335 compared to the full kit being $549.00 all prices include xpresspost shipping from canada (3-5 Day)
    Need parts for your Northstar Engine? www.northstarperformance.com
    Evrett, Sales Executive of the SureGrip™ Cylinder Head Stud Kit
  12. #26
    Tailfin's Avatar
    Jan 2004
    34
    803
    Thanks for that information. That would mean completely dropping the engine...a feat which I've avoided due to lack of the hoist and such...but I will keep it in mind as an option opposite that of suicide if I have a problem :-P.
  13. #27
    Oct 2012
    Manitoba, Canada
    376
    we take the engines out of the top it isnt impossible and 90% of the time makes certain things easier such as never touching the subframe there is no chance for need of re-alignment, also dont have to touch brake lines or anything of that sort
  14. #28
    Tailfin's Avatar
    Jan 2004
    34
    803
    Hehe yeah top or bottom, it takes equipment I wasn't prepared to purchase just yet. I'm doing it in the car. A few things are a real pain, but still didn't seem worth pulling everything to me.
  15. #29
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,873
    Quote Originally Posted by Tailfin View Post
    You cant do studs with the engine in the car, only TimeSerts..
  16. #30
    Tailfin's Avatar
    Jan 2004
    34
    803
    Yeah that's what I just said a couple posts ago...here:
    I'm using the NS300L inserts...read too many bad things about TimeSerts. Plus, they practically admit it...by having BigSerts. Makes me nervous when they come out with a product to fix their first product haha.
    I'm almost done. Just have to put a fan, the coils/wires, the surge tank and a few other mechanical viscera back on and then I pray haha.
  17. Remove Advertisements
