Blown head gasket repair
Results 1 to 5 of 5
Northstar Engines and System Technical Discussion Discussion, Blown head gasket repair in Cadillac Engine Discussion; Has anyone tried any of these fix a blown head gasket miracle cure products? I.m looking at a 1999 deville ...
    torelle is offline Cadillac Owners Member
    Automobile(s): 1996 Deville
    Apr 2004
    Florida
    60
    Has anyone tried any of these fix a blown head gasket miracle cure products? I.m looking at a 1999 deville with 120,000 miles that overheats but with no typical signs of a blown head gasket. Just want to know if these hawked fixes work in case that is what is wrong with this vehicle. Thanks for all responses.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,534
    Re: Blown head gasket repair
    Read the engine, cooling system, and gauge stickys above this post, then search the Northstar and Deville forums for years of discussion on this constantly recurring subject.
    Diagnose the problem before resorting to a temporary snake oil fix - head gasket failure is but one of quite a few Northstar "overheating" problems.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    28
    26,325
    Yes.
    Any amount of searching will tell you that NONE of them will work, they are very likely to cause blockages, and they will leave a very difficult-impossible to clean mess behind in the coolant passages and cooling system that will have to be cleaned during proper repair.
    If the problem was JUST the gaskets themselves, snake oil MAY provide a temporary seal (along with all the above problems). But the problem with the Northstar is pulled head bolt hole threads in the block. You cannot seal an ever moving, ever widening breach.
  5. #4
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,871
    Quote Originally Posted by torelle View Post
    They dont work, especially on a Northstar. Unless it can miraculously re-thread the holes in the block that the head bolts go into..
  6. #5
    Ranger is online now Cadillac Owners Member
    68
    81,741
    There goes another '99.
    The question has been asked a million times and the answer is always the same. DO NOT waste your money on that snake oil.
  7. Remove Advertisements
