How to pull this out ?
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, How to pull this out ? in Cadillac Engine Discussion; What is the best way to pull this out ? The guides for the cylinderhead is already pulled out on ...
    CooL is offline Cadillac Owners Member
    Automobile(s): Seville STS
    Apr 2004
    11
    What is the best way to pull this out ? The guides for the cylinderhead is already pulled out on this picture!
    Thx
    CooL
    growe3's Avatar
    growe3 is offline Cadillac Owners Enthusiast
    Automobile(s): 1993 STS and 2004 DTS
    Oct 2003
    Cameron Park, CA
    564
    Re: How to pull this out ?
    I use a large pair of Channel Lock pliers. Grab tightly, twist with slight upward pull. It will take a few partial turns to get it out.
    Another way is to put a steel rod in the head alignment dowel, grip the dowel tightly with Vise Grips, and then using a hammer tap and outward to remove.
    Replace with new dowel pins.
    In either case take precautions to avoid any damage to the engine block. The aluminum is very soft and a scar can cause a new head gasket leak.
    -George
