Page 1 of 9 123456789 LastLast
Results 1 to 15 of 130
Thread: 2001 ETC Intermittent High Idle
    ontarff is offline Cadillac Owners Member
    Automobile(s): 2001 ETC
    Sep 2007
    United States
    93
    I experienced and seemed to have resolved an intermittent high idle problem. Occasionally the idle speed does't fall below 1200 rpm or higher causing a high coolant temperature. No DTC. I removed the idle air control (IAC) valve. It had a lot of soot on it. I cleaned the plunger, shaft and hole where it was mounted thoroughly with carburetor cleaner. I also cleaned the throttle body that wasn't too dirty. I wanted to replace the throttle position sensor (TPS), no DTC, but couldn't get to the retaining screws with a screw driver!
    Does anyone know how to remove the two Phillip's head retaining screws on the TPS? There is not enough clearance for a 90 degree screw driver to fit between the screw and a thick metal piece where the coolant crossover is mounted. The repair manual does not explain how to get to the screws other than removing the water pump belt cover.
    69
    82,262
    Re: 2001 ETC Intermittent High Idle
    You'll probably have to remove the TB, but Usually the TB is the culprit. Hard to imagine it was clean, but the IAC valve wasn't.
    LloydCFerguson is offline Cadillac Owners Member
    Automobile(s): 1997 ETC, 2002 STS
    Mar 2012
    Glendale, CA
    45
    I've found that servicing things on the drivers side of the engine usually requires removing other parts, that is just the way these cars are. Removing the waterpump belt cover is not that difficult and gives you the chance to check the belt and tensioner while you are in there.
  5. #4
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,675
    Quote Originally Posted by ontarff View Post
    ASSUMING you pulled the codes correctly -
    if the TPS was defective - or not responding - or out of range -
    a code would be set -
    throwing parts at the car is RARELY the answer -
    and is definitely the most expensive method of repair -
  6. #5
    Sep 2007
    United States
    93
    OK, I removed the throttle body to get to the TPS. I replaced the TPS. I was driving home today and AGAIN got a high idle problem. I don't know how to solve the problem now. I cleaned the thottle body, replaced the TPS and IAC and the problem still exists. Please advise
  7. #6
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,675
    ASSUMING you checked that the gas pedal is not hanging up on the floor mat -
    and the throttle cable itself is not binding somewhere -
    and the throttle plate is not binding on anything -
    step #1 is ALWAYS check for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
  8. #7
    2kflhr's Avatar
    2kflhr is offline Cadillac Owners Enthusiast
    Automobile(s): '10 Escalade, '97 Eldo ETC (Z)
    Dec 2004
    Mooresville, NC
    58
    904
    Are the throttle cable connection points lubricated?
  9. #8
    Sep 2007
    United States
    93
    Quote Originally Posted by basscatt View Post
    No DTCs, Problem occurs after a warm restart and engine comes up to normal operating temperature (at twelve o'clock).
  10. #9
    Sep 2007
    United States
    93
    I haven't lubed them. I will and advise (with my fingers crossed!).
  11. #10
    Sep 2007
    United States
    93
    I lubed the throttle cable attachment point and where the spring rubs next to the pulley. Could it be something wrong with the computer?
  12. #11
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,675
    a computer or sensor malfunction should set a fault code -
  13. #12
    Sep 2007
    United States
    93
    Question Idle problems - 2001 ETC
    2001 ETC with 69,000 miles. - I am having an intermittent high idle problem on a warm restart. Sometimes the idle RPM will not go back down below 1100. This causes a high coolant temp. (1-2 ticks). I cleaned the throttle body (not very dirty), throttle plate and replaced the IAC first, then installed a new TPS. Problem still occurs. Could it be the ECU? I noticed that since I replaced the TPS, on a cold start, initial RPM is 1100 for about 20 seconds and then drops to 900 but hunts a little between 850-950 when I put it in gear (R or D). 650 RPM when up to normal temp (gauge just a little past 12 o'clock). No coolant leaks, no DTCs.
  14. #13
    Sep 2007
    United States
    93
    No DTCs.
  15. #14
    Submariner409's Avatar
    Submariner409 is online now If it won't run, chrome it
    Feb 2006
    MD Eastern Shore, Kent Island
    56,794
    Re: Idle problems - 2001 ETC
    Your cold start fast idle sequence is correct, but not the "hunting" during the 900 rpm part.
    Vacuum leak ? An EVAP problem (vacuum leak) would set an emissions (P) code. Clean the IAC plunger ? I doubt the PCM is at fault.
    Even a high idle, if left alone for a few minutes (HVAC off), would cause the fans to turn on at 224 degrees - just less than one tick past the center position on the gauge. The engine then cools to 214, fans shut off, and the cycle begins. If the HVAC (A/C compressor operation set) was on, then fans run in SLOW all the time, so the engine should not heat much past the center mark, if at all.
    Study the stickys just above this thread - fans, gauges, cooling system operation.
  16. #15
    JoeTahoe is offline Cadillac Owners Enthusiast
    Automobile(s): 2001 GMC SLT, Malibu LTZ, 99 STS studded with NP
    Jul 2010
    Central, NY
    49
    499
    any engine codes. could be intake plenum is dry rotted and leaking
  • You may not post replies
