Advice on NorthStar coils - both ignition types
Results 1 to 6 of 6
Northstar Engines and System Technical Discussion Discussion, Advice on NorthStar coils - both ignition types in Cadillac Engine Discussion; Need some help. I've had service recently on both of my Cadillacs, a 1995 Eldorado and 2000 DTS, both with ...
    johnm7 is offline Cadillac Owners Member
    Automobile(s): 1995 Eldorado Touring Coupe; 2000 Deville Touring Sedan
    Sep 2011
    1
    Need some help. I've had service recently on both of my Cadillacs, a 1995 Eldorado and 2000 DTS, both with the Northstar V-8. After each service visit, each engine had an engine coil go out less than 30 days after service. Is this a phenomenal stroke of bad luck, or is something amiss?
    vincentm's Avatar
    vincentm is online now Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,872
    Stroke of bad luck.
    68
    81,894
    Re: Advice on NorthStar coils
    They have totally different coils.
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    2000 has the coil module? Did u put in a new module or use one?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,856
    There's nothing to prevent a 1995 waste spark coil ( 1 of 4 ) going bad or a 2000 cassette system coil ( 1 of 8 ) going bad either. CF has many instances of either type of ignition system losing a coil ........
    Bad luck.
    Pictures/diagrams of both system types in my albums.
    eldoedwardo is offline Cadillac Owners Fanatic
    Automobile(s): '99 Eldorado coupe
    Mar 2011
    KCMO
    62
    161
    Re: Advice on NorthStar coils - both ignition types
    hey guys, I don't know what sort of service you had performed, but I do know its very easy to lay an arm or droplight or hit the coils with a ratchet handle. moving old wires or connections should be handled carefully, not really what someone does when working for pay. just sayin'...even simple oil changes by others don't always go right. no one will take care of your car like you. subscribe to alldataDIY. and keep asking the good group of people at this sight.
    if it doesn't come loose fairly easy find out why, leverage is not always the answer. turn a wrench and save da money, later Ed
  9. Remove Advertisements
