Which Fuel Pressure Regulator?
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, Which Fuel Pressure Regulator? in Cadillac Engine Discussion; On rockauto.com it lists 3 differant part numbers for fuel pressure regulators. One says "1st design; used with nylon fuel ...
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    On rockauto.com it lists 3 differant part numbers for fuel pressure regulators. One says "1st design; used with nylon fuel rail" and the other says used with stainless steel fuel rail. The other doesn't say which. I just got the stainless steel rail today, but I thought they put the old FPR on it? In fact I know they did...
    So what's the deal with there being 2?
    Also, I pulled the vacuum line before I took the FPR off and it was leaking a little bit. Then when I put it back on and secured the clip again it didn't seem to leak. Shouldn't it either leak or not leak?
    This is what mine looks like.
    Hason560 is offline Cadillac Owners Member
    Oct 2003
    49
    Re: Which Fuel Pressure Regulator?
    well the o ring could have not been sitting right. i sell delco to the caddilac place here in gainesville florida and i must send 5 of the new fpr over there per day i belive they are only a couple of dollors.
    mtflight's Avatar
    mtflight is offline Cadillac Owners Connoisseur
    Automobile(s): 1999 White Diamond ETC
    Jan 2005
    Dallas, TX
    2,538
    If it was leaking, Dave, it probably needs to be replaced.
    you idle the engine, and pull the vacuum line off... it's supposed to be leak-free. (And I heard the hissing from the vacuum line).
    If you need a good place to get the part, I know a place... PM me. They may even help you get the right one.
    Regards,
    Alex
    Quote Originally Posted by davesdeville
