Northstar engine miss
Results 1 to 8 of 8
Northstar Engines and System Technical Discussion Discussion, Northstar engine miss in Cadillac Engine Discussion; Hey there all of you die hard caddy lovers(just hacking on ya)I'm trying to keep a sense of humour but ...
    rangatang is offline Cadillac Owners Member
    Apr 2005
    49
    CoolNorthstar engine miss
    Hey there all of you die hard caddy lovers(just hacking on ya)I'm trying to keep a sense of humour but here is my delema:
    I have a 94 Eldo that I have admired for years.It was the deal of a lifetime I thought.Car is a rocket on wheels and I love it or I would get rid of it but I bought it knowing it had a miss at idle.I have drove the car about 300 miles and the antifreeze doesn't drop a bit,no leaks and I have done a leakdown test which was fine.I did a compression test and found the #5 cyl. at 60 lbs.I never got any antifreeze out of the plug hole when I did the leakdown test so now I'm thinking it's a stuck valve.
    Is this common on a Noerthstar?
    I put a can of combustion chamber spray thru it and it runs a lot smoother but still has bad compression.
    I bought the car from the original owner who is 80 years old and always had the car serviced at the dealer
    The car has 160,000 miles on it and looks like new.I paid 1400 bucks for the car so I don't mind dropping some money into it.
    The old fart that I bought the car from always has a smile on his face when he asks me how i'm doing with the car.I think he has it in his head that he put one over on me but even if I have to do a total rebuild on the engine I'm going to tell him it was just a faulty spark plug .That will get him spinning.
    I will try to pinpoint the problem today...thanks
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    Re: Northstar engine miss
    Did you do a leakdown test and a compression test?
    When you did the leakdown (pressurizing the cyls) did you hear air leaking somewhere? I would be looking at stuck rings first although that is pretty low compression. Did you squirt oil onto that cyl and run the test again to see what it did?
    97BlueDeville's Avatar
    97BlueDeville is offline Cadillac Owners Member
    Automobile(s): 06' DTS
    Sep 2004
    Aurora, CO
    41
    65
    Spray Compressed Air into the Bad Cylinder, and look for bubbles in your Prezzure tank.. If bubbles bad Head Gasket. If no bubbles spray from 20W oil in the cylinder and check compression, if it goes up bad rings or broken ringlands.. If it does not go up might be a bad valve spring or bent valve but that's unlikely...
    Good Luck..
    Clint
    Apr 2005
    49
    Thanks for your input zonie77.I did the compression test on all cyl. aqnd they were from 155 to 180 lb. except # 5 which was around 60.I put a rad tester on and pumped it up to 15lb and left it on overnight and it only went down 2 lb.I rolledthe engine over and nothing came out the plug hole.Thats what has me thinking it's a stuck valve.You are right tho,,I should have put some oil down the cyl. and did another comp.test.I'll do it again in a few days and see what I get.I'm thinking that the engine may have to come out...thanks again....Rangatang
    ktills45 is offline Cadillac Owners Fanatic
    Feb 2004
    North of Philly
    493
    Quote Originally Posted by 97BlueDeville
    Good Luck..
    Clint
    Would you care to write a paper on this procedure, Hmmm?
    Apr 2005
    49
    Hey there,thanks for the input.I have been checking the forums and I haven't found a problem with a single cyl having a valve problem.
    I know that this car has been babied since new and I would have thought that all of the cyl.would have a cop. problem if 1 did.What I mean is ..All of the cyl. are between 170 and 180lb. except for #5 which is at 60.
    I sprayed a whack of combustion chamber spray down the cyl.and let it sit for 3 days.Today I will start the car up and let it warm up,then I will put some more spray thru the throttle body.If no improvement I will put some oil down the cyl and if the comp. doesnt come up I will bring the cyl. to tdc ,hook up a differential comp. gauge and put 80lb. of air into the chamber.I will listen and if air comes out the exhaust then it is an exh. valve problem.If it comes back the intake then an intake valve problem.If it comes out the pcv valve its rings and I will lookor air in the antifreeze...Thanks again.. I will keep you posted...the Rang..
    Apr 2005
    49
    Got my 94 Eldo purring like a kitten.Found stuck rings in #5 cyl.Tried everything I could think of.Filled cyl. with combustion chamber spray and left for 3 or 4days but didn't help.I was about to pull engine and a friend of mine suggested filling the cyl. with diesel fuel.Left it for a week and I couldn't believe my luck but a least one of the rins came loose as I have 155lbs in the bad cyl. The rest are around 180.
    Now for some stylin and profilin...in style.I'm givin her a good rod stretchin..Thanks to all.. the rangatang
    Sep 2004
    Aurora, CO
    41
    65
    Diesel fuel.. Interesting...
    Glad it's better...
    Clint
  11. Remove Advertisements
