Are there certain northstar engines to stay away from?
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, Are there certain northstar engines to stay away from? in Cadillac Engine Discussion; I'll probably be in the market for northstar engines from time to time for use in off-road vehicles. Are there ...
    DAG
    DAG is offline Cadillac Owners Member
    Jul 2004
    5
    I'll probably be in the market for northstar engines from time to time for use in off-road vehicles. Are there years or versions that are better than others?
    TIA
    Dan
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    Re: Are there certain northstar engines to stay away from?
    Well the VIN 9 engines are usually 300hp and the VIN Y are 275. 93-95s were OBDI computer controlled, which is possible to reprogram whereas later models were OBDII which is much harder and sometimes impossible.
    Just curious though, why a N*? Offroad vehicles are usually heavy and need a lot of low end torque, while the northstar makes its peak torque at 4000/4400. They're great for light things and are used in a lot of sandrails but not trucks and 4x4s.
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    A lot of rock crawlers are starting to use them also for the light weight.
    BeelzeBob's Avatar
    Dec 2002
    52
    9,577
    Quote Originally Posted by DAG
    TIA
    Dan
    You are probably more interested in the 93 thru 99 engines... Beginning in 2000 the engines were substantially redesigned with a roller valve train, revised heads, etc... The fuel economy improvement with the roller followers and the LEV emission requirements were the driving force for the redesign, not HP. The 93-99 engine had the flat follower cam design and are somewhat simpler and more oriented for performance modifications.
  7. Remove Advertisements
