Engine miss when HOT outside.
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, Engine miss when HOT outside. in Cadillac Engine Discussion; Any ideas what could cause a miss when in DRIVE at 1300RPM's (foot on the brake) when engine is at ...
    Caddynut is offline Cadillac Owners Member
    May 2005
    21
    QuestionEngine miss when HOT outside.
    Any ideas what could cause a miss when in DRIVE at 1300RPM's (foot on the brake) when engine is at operating temp and it is 60+ degrees outside? It may miss at lower RPM's but more prevelant then.
    May 2005
    21
    Re: Engine miss when HOT outside.
    No guesses even?
